Are 5 and 6 speed boxes a direct swap?
Started by Iain, September 19, 2022, 18:06
Iain
My 6 speed box in my 2 has a noisy input shaft and getting worse so one day the time will come to replace it. Is swapping to a 5 spd a straight swap? Will my LSD swap over boxes?
As my car is purely for track use im thinking going for a 5 spd would suit better as ive read they're a smoother box.  Is this true?
And if all works out maybe i'll get super lucky and find a JDM box 😬
The 5 speed is definitely stronger and, many think, a bit slicker.
I can't see any reason why they won't just swap, but you'll need a five speed shifter to go with it (???).  I stand to be corrected on this.
Unless you're getting a JDM box with no LSD, all the Euro boxes have LSD.
Finding a JDM box with LSD is looking for hens' teeth, but one from a Euro box can be swapped in.
Iain
Thanks Carolyn.
Im happy to keep my 6 speed shifter, just change the knob. Unless anyone knows theres a difference?
Quote from: Iain on September 20, 2022, 10:05Thanks Carolyn.
Reverse is in a different place.
Beachbum957
Both shifters should interchange.  We are running a 5 speed shifter on a 6 speed. Apparently, the only difference is the 6 speed shifter has slightly more side to side clearance to get to reverse (left and front). Since the 5 speed reverse position is where the 6 speed 6th gear position would be (right and back), the 6 speed shifter should work fine.
