You and your 2
Started by Zxrob, October 8, 2022, 21:05
Quote from: Dev on October 23, 2022, 22:06My only regret was not buying the TRD start button and replacing the Lexus one which is a direct plug in.
Thanks for that tip. Had not thought of that and will look into that!
p.s. WOW!!! Pricey.
Quote from: Petrus on October 24, 2022, 08:24Thanks for that tip. Had not thought of that and will look into that!
p.s. WOW!!! Pricey.
There are different versions of the TRD button. The one I need has the led indicator light on the start button. That one is super expensive. I am fine with the gray and I found over the years having it not stick out makes my interior more believable as OEM. Dat is what makes people excited when they find it. Less is more.
Quote from: Dev on October 24, 2022, 15:26Less is more.
 :))  :))   yet I added fog lights  :-[
Went properly against my grain but in the end the additional safety margin of additional ´stray´ light on unlit nightly twisties outweighed the all plastic mini lamps.
As an unexpected bonus I think it even looks better. The Disney-esque softy smile of the pfl is now a competent grin. Yesyes, taste etc.
Had the gf arm flapping about them btw.
She observed that the caps would need be removed before using the lamps. No issue, I said, as she could do that ever so elegantly and swift upon my command.
Went she was breathing normally again I pointed out it, because they are lower, is to protect them from grit/stones.
Ah, that makes sense...
Ok. Then I like them too.
It helps they are cheap  ;)
