Wind noise
Started by edward.carter, November 18, 2005, 09:28
edward.carter
At "Motorway speed" this morning and noticed some wind noise coming behind me over my left shoulder, could it possibly be wind coming in through the side vents and up the drainage holes, what do you think?
Ta   s:lol: :lol: s:lol:
check the seals that follow the door line down on the roof, mine got caught up on this and sometime even went completely the wrong side causing an annoying rush of air noise
edward.carter
cheers will do, did put my hand across by the door and couldnt feel anything, will check it out though cheers   s8) 8) s8)
Hi, I had this. I found that part of the rubber strip between the side windows and the roof had become tucked underneath the hood after the hood had been lowered and raised. Gently pulled them back out and the noise went away.
Hope this makes sense and sorts your prob out   s:) :) s:)
edward.carter
Your prob right, last time i brought the roof up it was quite stiff and i thought it was due to cold or something put it was probably that strip you talk about, cheers guys, gotta love this place   s:D :D s:D
