umm when i tap on my breaks the hand break light flashes at the exact time as the battery light...
only for a split second sometimes when breaking...
how weird? a loose connection maybe?
I'd take the car back to your expert MR2 mechanic friend. Something's definately not right there.
lol - no don't - lol - ratflmao
Quote from: "leon_in_uk"umm when i tap on my breaks the hand break light flashes at the exact time as the battery light...
Maybe its time for a Kit Kat seeing that its a problem with the break!
Ill get my coat*
Quote from: "Ekona"I'd take the car back to your expert MR2 mechanic friend. Something's definately not right there.
good idea he needs teh practice
Quote from: "markiii"Quote from: "Ekona"I'd take the car back to your expert MR2 mechanic friend. Something's definately not right there.
good idea he needs the practice
But by the time he has it back on the road, summer will be over s:( :( s:(
Leon, have you found several empty Sake bottles in your 2? wondering if it was a party that Friday afternoon in Tokyo when your beast was built s:?: :?: s:?:
more likley pints of M&B in the midlands when his engine was put in :-) :-) :-)
jeezus!!! post a seemingly rational and serious question and the guy gets assasinated!!! s:shock: :shock: s:shock:
I mean, I know the guy possibly doesn't do himself any favours, but this is all probably a bit harsh!?
remind me never to get on the wrong side of you guys!! s:wink: :wink: s:wink:
Quote from: "jamesr1"jeezus!!! post a seemingly rational and serious question and the guy gets assasinated!!! s:shock: :shock: s:shock:
Yes sorry - you're right. I posted a similar post to yours in one of Leon's earlier posts - seems I've now fallen onto the darkside of this ongoing soap opera.
Sorry Leon, but you seem to deal with all these problems with impressive good humour s:D :D s:D
Re. the problem - The handbrake light is also the warning light for any (non ABS) problem in the braking system - such as low fluid / pads / faulty master cylinder etc (am I correct?)
In which case, is the first port of call to check fluid levels / and visual inspection of brakes to ensure safety?
Based on the fact the battery light is coming on too, would suggest a minor electrical problem? I can't think of an issue off the top of my head that would cause both. The only thing I can think of (that is a real problem) that illuminated the battery intermitently is a alternator belt slip / faulty alternator. But can't see how it would be related to the brakes..
IN short, I'm confused.
Err, suppose you've checked your brake fluid levels
Leon,
I suspect that you could be low on brake fluid or an ABS sensor has gone duff. Definately check the brake fluid immediately though, if you haven't already!
[edit - beaten to it whilst thinking!]
Quote from: "Richie"Leon,
Richie, is there a seperate ABS light? would look, but too lazy to go outside!
Low fluid would make sense if flashing when braking, as presumably the sensor is in the reservoir and the level dips when brakes are used.
The fact that the battery light comes on as well would be pointing me toward an earth problem, probably somewhere around the rear light cluster or it's associated wiring..
But, of course, it could also be a bad earth on the cluster or somewhere else, and the fluid idea might be on the mark (or fluid level indicator).
IIRC the 'charging circuit light' (aka the battery) lights up when the alternator is not producing a current because the alt circuit goes 'open', leaving the battery light as the only path to the -ve of the battery.. it shouldn't come on for any other reason than something electrical.
Quote from: "Chris_h"Quote from: "Richie"Leon,
I'm not sure now that you mention it mate - and me too!
QuoteLow fluid would make sense if flashing when braking, as presumably the sensor is in the reservoir and the level dips when brakes are used
That was my thinking too.
As for the battery light flashing on, I was trying to think of a possible electrical fault that might cause that (if its none of the above) but can't think of anything specific asides poor earths or bulbs shorting in the light cluster
It could be Leons ECU wiring as I seem to remember he had problems in that department straight after the engine swap (Engine wouldn't Start)??
Yes there is an ABS light - comes on and self-extinguishes if OK at start-up.
Leon. I take it this is a problem that has started recently and not one that has been present since the engine swap?
My thinking re. handbrake light is along the same lines as the posts above (fluids), but that would make the ignition light issue no more than a very bizarre coincidence.....
.....so now I'm wondering if you shouldn't return to all of the wiring that was disturbed during install and do a double-check.
Hmmmm.
ok i will..
it hasnt come on in a while just last week it was flashing on and off etc. but only very quickly.
i have only just read all the posts so my first thing i will do before i drive will be to check all the fluids.
it didnt light this morning at all, so maybe just a very minor problem
We had this on our Focus, did come on all the time, but it turned out to be brake fluid, there was a leak.
Hardly a minor thing not having any brake fluid, so I would suggest you do check it regardless of whether the light is on now. I wouldnt want to be the guy you run into the back off knowing that you could have an issue with your brakes.
right, travelling down the motorway yesterday, after checking my fluid...(it was on the max level and fine)
the two lights were coming on more frequent... so i did a little test.
every time i went over a big bump etc they are more likely to come on. and when i make the car jault left and right etc on a safe road the light comes on for each jault, as if the fluid is low but its not!!
i got in my car this morning and the first thing it did is show both lights for about 30 secs, and then flashed on and off on my journey to work..
the breaks seem normal, and so does the car! what could this mean?
the sensor??? or a dodgy connection??
love the technical fault finding.................NOT!
you need to trace the wireing thru to determine the fault correctly, all your going to achieve by this course of action is a knackered set of tyres and still no idea what the hell is happening. Do it properly or take it back to your master mechanic
i did have alook at all fuses linked. and tried to follow wires. but im not a mechanic i didnt have a clue about the earthing etc.
the only thing i can do is take it to that mechanic... hopefully he will find a fault, but if not a trip to toyota.
I had similar symptoms years ago in my old Scimitar. The fluid level was fine, but the warning lamp kept coming on. It took me some time to determine that the problem was due to the float - it was made of cork and had become saturated, at which point it no longer floated very well!
I guess floats are no longer made out of cork, but perhaps the float may be punctured?
shall i dip around the break fluid then? s:D :D s:D maybe do some fishing...
right, the lights dont come on now when i break, just when i accelerate...
which has changed, but they stay on alot longer. toyota want £62 for an hours labour to do a diagnostic test and to test the problem....
i think they are a rip off...
am i better taking to an auto electrician?
thanks
If you can find a good auto electrician (they're hard to come by these days) then yes, absolutely..
Hang on... Almost two weeks on with a dodgy brake light flickering away on your dash, and you've still not got it fixed?! s:shock: :shock: s:shock:
Words ---> Me
Come on Leon, I'm not trying to be harsh here mate but you really need to bite the bullet and just get it checked out ASAP, else you could be introuble if something is seriously wrong and drive into the back of someone at 70mph+...
its not the brakes...
i have been told by the auto electrician it maybe the alternator... he said he has had toyota's do similar before and needs to test if the alternator is working properly or not!!
the cars fine, itself and there is no major problem. it drives and brakes fine, why would i rush.. i dont drive often...
Quote from: "leon_in_uk"i dont drive often...
s:shock: :shock: s:shock: crikey! you may not drive very much, but I don't think your brakes will say to themselves "i know, we'll go easy on this one and keep stopping the car cos he doesn't really work us that hard!"
It's not like having half a tank of petrol and thinking "oh well, I'll fill it up next weekend cos I don't really use much petrol", it's more like skydiving and thinking "I'll get my chute checked for fraying and degradation next month cos I only do one dive a week"... s:? :? s:? s:shock: :shock: s:shock:
Quote from: "leon_in_uk"its not the brakes...
That's kinda missing the point.
You don't know
for a fact that it's nothing to do with the braking system (hence the "maybe it's the alternator"), and yet you're still driving it. As James said, it doesn't matter if you drive 1 mile or 1000 miles, things could stop working at any time.
Put it this way, if it were me I wouldn't even dream of driving it until I had the problem nailed down.
FWIW, I'd agree with the auto electrician - if the battery light is coming on it's almost certainly the charging circuit.
In fact... I'm sure I said that quite a few posts ago... s;) ;) s;)
Quote from: "aaronjb"...it's almost certainly the charging circuit...
but not
definately!!!
some unfortunate soul could
almost be dead...! s:wink: :wink: s:wink: s:? :? s:?
so if it was the charging circuit, would that explain my heavy steering some time ago?
how much for a new alternator? fitted?
Quote from: "leon_in_uk"how much for a new alternator? fitted?
pass, ask mr.T
But check all the connections and earths, belt tension etc
May have been disrupted / not put back correctly during all the engine woes.
Is it still you're existing alterator?
yes it is.. i am taking it to have the alternator checked to see if its charging properly..
hi guys, got it checked on friday. told ya nothing to worry bout... s:wink: :wink: s:wink:
he tested the alternator and when i revved the battery light came on. it a slight dim in the circuit. and said wont affect my charging/alternator unless its on all the time. a quick flick of the lights wont really make a difference to it charging. said to run it for a couple of months and it might go...
if it gets worse i will change the alternator. but at £165 its expensive, oh and the fitting, will i have to take the engine out?
what about the other (braking) light?
its the handbreak light, connected to the charging circuit. and represents the same problem, just a glitch in the system. for a second or so...
i might give my battery a good charge to see if that does anything!!
