Whats the best wiring route to follow, from the amp to the battery?
I've used the shortest, from the passenger's side bin, just over the bars, to the battery.
It looks ok, but I'm wondering if the heat that the engine produces, will make any damage to the wires.
Any photo/diagram or advice should be helpfull.
Quote from: "SimosSpyder"I've used the shortest, from the passenger's side bin, just over the bars, to the battery.
Since you're in Greece, I assume your passenger side is the right side of the car?
I used the same premade hole where the engine loom goes through, on the left side of the car, behind the battery. Can't imagine that having any heat issues.
same here, mines been in there for 3 years, no issues at all
Ok Thanks
Quote from: "kanujunkie"same here, mines been in there for 3 years, no issues at all
Same with mine but not quite 3 years s:wink: :wink: s:wink:
