The Workshop => Audio / Security / Electrical => Topic started by: Anonymous on October 28, 2003, 19:49
Title: Radio Clock Display
Post by: Anonymous on October 28, 2003, 19:49
2002 Model
Standard head unit
Why will the clock not change back to winter time  s:?: :?: s:?:
Still read 18:00 at 17:00 today     s:( :( s:(
Post by: Anonymous on October 28, 2003, 19:54
As a guess have you got the radio tuned to a FM station that transmits the time signal (BBC fo instance) Most radios need that for the time function to work.
Post by: Anonymous on October 28, 2003, 19:55
Think you also need to set the settings so that CT shows top right.  Then on an FM station for a few minutes and all should be ok.  As I understand the time signal is sent with the station information.
Post by: SimonC_Here on October 29, 2003, 09:22
Think I got a duff (read old) HU in mine. No TA, no AF  s:( :( s:(  (at least the arial goes up and down when I want it to!)
I have to change the time manually. Can't quite get the Minutes right yet. must RTFM.
Simon
Post by: Anonymous on October 29, 2003, 19:12
Tried Radio 1, 2 & BBC local radio station for 15 minutes each.
CT is on.
TP is on.
AF is on.
Time still 1 hour ahead 24 hours on from 1st post   s:? :? s:?
I can't get broadband in North Lincs, perhaps they don't broadcast fancy radio in these parts either  s:!: :!: s:!:      s:lol: :lol: s:lol:
Post by: Anonymous on October 31, 2003, 18:35
Did you know that the pre 03 model radio clock is manually adjustable  s:?: :?: s:?:
Found out today, after i was sat in a traffic jam for an hour, so i started to fiddle with the radio. If anyone wants to know I will see which buttons i pressed & post it on here. If not i will keep it to myself  s:!: :!: s:!:
Post by: SteveJ on October 31, 2003, 19:14
Quote from: "SilverMSD2"Tried Radio 1, 2 & BBC local radio station for 15 minutes each.
CT is on.
TP is on.
AF is on.
As my radio is still stuck at Salford  s:evil: :evil: s:evil:  I can't confirm this, but mine only seemed to change when it received a traffic broadcast using the CT setting
Post by: Anonymous on November 2, 2003, 12:06
Ok, to reset the clock manually on a pre 03 model press the following buttons:
Shift
Set-up ( 8 )
Right Arrow ( 10 )
Then twist the volume control.
Hey presto     s:D :D s:D
Title: Re: Radio Clock Display
Post by: Anonymous on June 18, 2013, 18:25
thank you so much on your advise it worked a treat regards nidge h
Post by: dcod on June 18, 2013, 19:06
 s:shock: :shock: s:shock:
Could this be the oldest ever resurrected thread? 2003!
Nidge h, I think you'll find he's 'left the building'   s:( :( s:(
