Just bought a Pioneer DEH-p70BT, how hard i it to fit, been quoted £60 to fit it.
Is it a case of swapping the head unit and plugging back in the attachments alreday in teh present head unit into the new one.
depends on what is already in your car?
kenwood KDC-W410 single din stereo.
then assuming it was fitted properly with teh correct ISO adaptors and you have teh same for teh new unit
yes it it
Quote from: "markiii"depends on what is already in your car?
But, yes, do it yourself. Search for the instructions on here and, as Mark says, depending on what you currently have order in the fascia surround and/or Toyota-ISO connector and away you go.
I saved £120 fitting mine, plus there's the satisfaction of having done it yourself.
Steve
thanks, where sthe instructions on here ayone know thanks.
Whats all this ordering parts etc and removing fittings and panels around the head unit, can i not just slide it out and attach leads to new head unit and slide back in, there both standard uk head units, i alreday have the empty tray under the stereo.
I took out my double din and got the adaptor and fitted the single din myself, now if I can do it anyone can
- instructions are in the technical library - how to section.
Quote from: "Brad123"Whats all this ordering parts etc and removing fittings and panels around the head unit, can i not just slide it out and attach leads to new head unit and slide back in, there both standard uk head units, i alreday have the empty tray under the stereo.
rather depends if teh last owner used a standard didn cage or screwed it in from teh sides
not hard either way
how do i remove the stereo do i need those pin things.
Quote from: "markiii"rather depends if the last owner used a standard din cage or screwed it in from the sides
not hard either way
and failing that Brad, theres this nice little forum on here called "How to's" you'd have found all about it with the search button!
m http://www.mr2roc.org/phpBB2/viewtopic.php?t=12583 (http://www.mr2roc.org/phpBB2/viewtopic.php?t=12583) m
thanks guys, i fixed it, saved me £70, i also am well impressed with the handsfree function, very loud and clear.
cheers guys
