The Workshop => Audio / Security / Electrical => Topic started by: filcee on December 23, 2003, 12:30
Title: Q: Extra bits for replacing '03 head unit
Post by: filcee on December 23, 2003, 12:30
OK, I'm finally going to do it - I will replace my Fisher Price H/U in the New Year.  In the meantime I'm doing some research for the 'extras' I will need, so as to have all the bits ready to do this in one go.
I've had a look at the "EuroRoadster" web site.  This page lists some goodies for the pre-'03 model (in fact the article is about fitting a single DIN H/U on an import) http://www.euroroadster.com/articles/ShowArticle.asp?File=StereoReplacment.xml.  I'm looking at dropping in a single DIN unit, so from the bits listed on the web page:
What I think I need:
1 of 55521 -16030 : Tray / Storage slot
1 of 86221 -52050 : Left hand spacer
1 of 86221 - 52060 : Right hand spacer
What I think I probably have with my current H/U:
86211 - 17050 : Left hand mounting bracket
86212 - 17050 : Right hand mounting bracket
55423 - 17040 : Surrounding trim
Can anyone who has replaced an '03 unit with a single DIN one confirm (or otherwise) this parts list?
Ta.
Phil
Post by: Anonymous on December 23, 2003, 21:02
well a lot of people go this route by buying all Mr T parts but your better off getting teh autoleads facia adaptor, and then the faica trim from Mr T and this is job done !
You need the facia adapotor for a RAV 4 2000+ modle get this from halfords
Post by: Anonymous on December 23, 2003, 22:07
I have the autoleads facia adaptor with the built in cubby hole underneath (all one piece) it's the FP-11-03 adaptor   s:D :D s:D
Post by: SteveJ on December 23, 2003, 22:22
The brackets that come with the '03 OEM stereo will not fit a single DIN unit (they are specific to the '02 unit)
What you need are the mounting brackets for the pre revision Sony double DIN unit - any Mr T should be able to help.
Post by: Anonymous on December 23, 2003, 22:29
the FP-11-03 comes with the brackets built in to take either ISO screws or the metal frame, so no need to use the 03 OEM bracket at all  :-) :-) :-)
unless I'm missunderstanding?
Post by: Anonymous on December 23, 2003, 22:32
(http://www.muchos.co.uk/members/perry190/sterio%20bracket.jpg)
Post by: Anonymous on December 24, 2003, 16:04
flip out alpine screen i spot there perrry!
nice bit of kit if so!
Yeah the autoleads adapotor will fit any MR2 2000+
Post by: Anonymous on December 24, 2003, 16:45
well you've got good eyesight seeing that from that pic Buster, and yes your right! goes with my alpine sat nav, consequently one remote  :-) :-) :-)
Post by: Anonymous on December 24, 2003, 16:50
Quote from: "perry190"well you've got good eyesight seeing that from that pic Buster, and yes your right! goes with my alpine sat nav, consequently one remote  :-) :-) :-)
Well Buster is our ICE expert! Could you take some pics of it installed with the screen out... i would like to see how high the screen comes up etc...?
Post by: Anonymous on December 24, 2003, 18:00
will do. it'll be going in the next few days
Post by: Anonymous on December 25, 2003, 11:17
Oh if you havent already done it then you will need a spacer as the screen hits the top of the dash overhang!
Well my pioneer one dose! and i had to make a MDF spacer cover it in black carpet so it macheted the trim etc.
But the alpine m,ay swing out a little more than mine   s:!: :!: s:!:
Post by: Anonymous on December 27, 2003, 12:37
I've hacked the surround around so that the tray now sits at the top rather than the bottom, so hopefully that will bring the screen down enough?
Have noticed tho that the autoleads loom adaptor doesnt seem to match up with the conectors on the toyota loom?  Theres only two plugs that are the same size as the ones on the autoleads one but the pins in use dont seem to match is that right? (have checked a couple of sites and I do appear to have the right adaptor) ???
Post by: Anonymous on December 28, 2003, 18:01
thats what i done but found that it was too low down for vewing as the screen had to be tilted up a lot ! looked a bit C*ap but the alpine dose have better viewing angles
Post by: Anonymous on December 28, 2003, 19:00
it comes out ok and first impressions are good, but will have to see if visibility is ok in a driving situation.  I wont be bothering with dvd or rear view camera this time around so its only really for the sat nav and snazzy display when in audio mode  :-) :-) :-)
Post by: Anonymous on December 28, 2003, 22:03
i hoked mine up to rear camera and front camera
found the best position to be on the rear bumper is the top grill and get a wide angle camera so that it helps you when reveersing
and the best place for the front camera was on the fron grill under the number plate as low to the ground as you can get it but all will be reviled when i finish it !
how's about side cam's to prevent kerbing my alloys?
Post by: Anonymous on December 28, 2003, 22:05
you mean wheel cam it has been done not on a 2 but other have got it called "curb cam" !
it simply a camera under the wingmirror looking down at the front wheel with a wide lense to pick up the back wheel!
only realy ever used on demo cars
Post by: filcee on December 30, 2003, 13:36
A bit more 'on topic'  s;-) ;-) s;-)
Just got back from Listers in Covo after ordering some bits to replace the H/U.  The service guy checked the parts numbers on the computer to see what is fitted on the '03 models.  It looks like you only need these three parts if you are replacing the standard 'Fisher Price' UK fit double-din unit:
55521-16030  Storage Tray/Slot
86221-52050 Left Hand Spacer
86221-52060 Right Hand Spacer
Price for all three bits was 26.30 inc. VAT, BUT, they are not in stock 'special order' so non returnable if they don't fit/work right.  They should have them in for me on Friday.
Once I get round to fitting the new H/U (haven't bought it yet - still no decision made on which one   s:roll: :roll: s:roll:  ) I'll be checking to make sure these are the right bits.
Post by: philster_d on August 3, 2006, 16:04
I removed the stock one and used the existing fittings. The new stereo is finaly secured solid with a few windings of black electrical tape. Thats the "Philster and Ste" Tm solution to your problem.
Cheers,
Philster.
Post by: filcee on August 3, 2006, 16:55
Philster,
Not sure what year & spec your '2 is, but mine is a UK-spec 2003 model, so came with the "Fisher Price" (Panasonic/Matsushita) double DIN head unit that I think might have been built to fit.  There was no OEM fitted spacer kit for the sides, and only a thin outer ring trim.  Swapping this for a standard DIN unit and pocket required the side spacers to fill the holes either side of the unit once fitted.
I think, but I'm not sure, that pre-03 UK '2s had the additional side spacers, and possibly a fatter outer ring trim, around the standard fit double DIN Sony unit.
As for imports - I don't know.  I seem to recall looking at an import at a car supermarket that didn't have a head unit fitted at all.  Can anyone shed any light on this?
t'other Phil
Post by: philster_d on August 3, 2006, 18:14
I taped it to the pocket bellow iirc
02
Post by: Graeme on March 7, 2007, 17:10
This picture has black side mounting pieces, where did you get them from? They don't come with the adaptor by the looking at this page: Clicky (http://caraudiosecurity.com/shop/product/products_id/3475.html)
I have the metal side mounting brackets (didn't come with the car - I had to buy them from MrT as somebody had previously "upgraded" the ICE (very badly). They look like this:
(http://www.mr2roc.org/Repository/misc/pictures/howtos/stereoinstall/pic6.jpg)
Graeme
Post by: Anonymous on March 7, 2007, 17:18
how does the fisher price come out?
Post by: kanujunkie on March 7, 2007, 17:39
amazingly if you search or look in the how to section you would find
 m http://www.mr2roc.org/phpBB2/viewtopic.php?t=12583 (http://www.mr2roc.org/phpBB2/viewtopic.php?t=12583) m
Post by: Anonymous on March 7, 2007, 17:42
found that stu, head unit is already removed though!
Post by: Anonymous on March 7, 2007, 17:49
The black side pieces do come with the adapter. Don't buy it from there though, I sell it cheaper  s;) ;) s;)
I sell it for £19 delivered   s8) 8) s8)   (mainland UK)
Post by: Liz on March 7, 2007, 19:26
Do you sell just the side pieces?
Post by: Anonymous on March 7, 2007, 23:07
Quote from: "nelix"found that stu, head unit is already removed though!
is it a case of following the instructions and its the obvious how the h/u comes out?
Post by: Anonymous on March 7, 2007, 23:46
Quote from: "Liz"Do you sell just the side pieces?
Unfortunately not. It comes as a whole kit.
Post by: Liz on March 8, 2007, 00:23
Can you bring a kit with you on Sunday pretty please?
Post by: Anonymous on March 8, 2007, 07:44
Quote from: "Liz"Can you bring a kit with you on Sunday pretty please?
Yes, of course  s:) :) s:)
Post by: Anonymous on May 29, 2007, 13:19
I've been trying to get hold of an FP-11-03 for a few weeks now.
Matt you have PM re: being able to supply one of these kits.
thanks,
Shaun
Post by: Anonymous on May 29, 2007, 13:56
Quote from: "ShaunyF"....Matt you have PM re: being able to supply one of these kits.....
Hmmm, no PM!   s:shock: :shock: s:shock:
You sent one to me?   s:?: :?: s:?:
Post by: Anonymous on May 29, 2007, 18:07
Oooops forgot to press send   s:oops: :oops: s:oops:    s:oops: :oops: s:oops:    s:oops: :oops: s:oops:
You have one now!
  s:) :) s:)
Post by: Mad Bob on September 13, 2007, 14:20
Quote from: "perry190"I have the autoleads facia adaptor with the built in cubby hole underneath (all one piece) it's the FP-11-03 adaptor   s:D :D s:D
I purchased this and recieved it. I put it in today but it has a gap all the way round, I thought that the original surround from the oem Sony unit may fit but it doesn't. Am I missing something?
Post by: aaronjb on September 13, 2007, 14:42
You need the fascia surround from the 2003 onward 'Fisher Price' Toyota unit, not the Sony.
One of these (http://www.mr2roc.org/phpBB2/viewtopic.php?p=227951#227951)
Post by: Mad Bob on September 13, 2007, 14:52
Cheers, just got one from Toyota. £15, mad, just paid £20 for the facia. Unreal how much I have spent out just personalising my in just 2 weeks.
Suppose I better get used to it.
Post by: uktotty on September 13, 2007, 14:54
Bob you may think you spent a lot in a few weeks, have a look at mine!!
Post by: Anonymous on October 23, 2007, 19:18
Quote from: "Mad Bob"
I also have this problem, the link posted afterwards no longer works though, can anyone advise me please?
Post by: Anonymous on October 24, 2007, 09:01
You need part no. 55423-17040-CO from Toyota
Post by: Anonymous on October 24, 2007, 14:27
thanks matt, just ordered one now for £15
