Anyone know how to remove the air vents in the middle of the dash?
Edited
See below
start by removeing the dash, HVAC panel and everything else, the vents sit in a Y shaped tube that sits on everything else, so unfortunatley they need to come out to get at it
Are you saying remove the whole dash or just the heater panel part?
whole dash
Oooh. Hmm. Sound's like a whole lot of work. Cheers stu
pretty sure it is, i was going to put some guages in there at one point until i came to the same conclusion
Yeah that was my plan. Gonna investigate it a bit.
if whatever you had in mind could just sit in the ducts the that would open up options
Yeah gonna replace the vent part with a chunk of Alu. A/F and some LED's and the display form a PFC comander in the other
Ok so question for anyone who has removed their dash.
What is the minimum you need to remove/undo?
Can you get away with not removing the steering wheel?
