Hiya i am having problem again. was going to fit myself a DVD player in but after took out the old stero out find out its a mess inside all the wire and cable be change.
wonder has anyone got a wire diagrame or and anyone knows the colour of the cables?
mine is 2001 model
Thank you very much s:bowdown: :bowdown: s:bowdown: s:bowdown: :bowdown: s:bowdown:
You probably need This, clicky. (http://www.mr2roc.org/phpBB3/viewtopic.php?f=51&t=14577)
Quote from: "nelix"You probably need This, clicky. (http://www.mr2roc.org/phpBB3/viewtopic.php?f=51&t=14577)
i know iso would help, but the problem for me at the moment is all the wire is be cut by the last owner and only can say its a mess there has no more adapter anymore. just cable hard around. >.<
Colours should be
Blue/yellow Power (on all the time)
Grey Power (from ignition switch)
Black Up/down signal to aerial
Violet LH speaker -
Pink LH speaker +
Light green RH speaker +
Blue RH speaker -
Brown Ground
Quote from: "cclarke99"Colours should be
Violet LH speaker -
Pink LH speaker +
Blue RH speaker -
Brown Ground
thank you very much
just get it sorted.
many thx
