Does anybody have one of these? are they any good?
(http://www.tandridgecanoe.co.uk/roadster/snooper.jpg)[/url]
If it's GPS based, I'd just stick with an Origin bluei thingy.
i've been let to beleive that the origin, was GPS only, whereas the snooper does that but also has a Radar and Laser Detector (RLD) built in as well and does detect the new portable mini-gatso
The Origin b2 already does GPS & Laser trap detection, and there's an optional radar detector module that's due for release in March '04.. Not cheap, mind, but I'll be getting one just as soon as I can afford it (and stop buying other bits in group buys first s:D :D s:D )
Aaron
march you say, hmmmmm s:? :? s:? , won't be wacking it around country lanes till then anyway, definatly something to think about, do you know how much the radar module will be?
Do many forces still use radar? I though laser was all the rage nowadays?
Only thing that still uses radar is Gatso and Mini-Gatso.
GPS will take care of the first, but they can be really sneaky with the portable mini-gatso's.
Quote from: "kanujunkie"march you say, hmmmmm s:? :? s:? , won't be wacking it around country lanes till then anyway, definatly something to think about, do you know how much the radar module will be?
All the RRP's are here (http://www.originb2.com/order.cfm), though no doubt it'll be available cheaper elsewhere (as the main unit currently is)..
have found the b2 for 375, not bad
got mine for £335
Didn't IMOC have a GB recently (just before crimbo as I recall), they were pretty cheap too.
still on
in that case i'm off to IMOC, c ya
Quote from: "markiii"still on
do you know where on IMOC, i couldn't find it, that site has no logical order to it, v.confusing s:? :? s:?
Quote from: "markiii"got mine for £335
where from Markiii
Perhaps post to the mailing list and see if someone can repeat the details.... I would offer to share, but I deleted the details long ago. Sorry.
Quote from: "phil4"Perhaps post to the mailing list and see if someone can repeat the details.... I would offer to share, but I deleted the details long ago. Sorry.
will do, thanks mate
m http://www.mr2roc.org/viewtopic.php?t=1917 (http://www.mr2roc.org/viewtopic.php?t=1917) m
Oh yeah, I put that post up didn't I s:oops: :oops: s:oops:
I have the details of the seller here if you want them kanujunkie..
Aaron
I have the Snooper S-6R Neo, bought it from w www.radargirl.com (http://www.radargirl.com) w back in October, very competitive prices !
The unit is very good, does everyting i need though i havent seen the Originb2 etc so couldnt compare. The only thing i would say is there have been no false alarms at all except if using the radar detector in built up areas - to be honest i switch it off mostly and only user GPS & Laser.
Quote from: "leon_judge"The unit is very good, does everyting i need though i havent seen the Originb2 etc so couldnt compare. The only thing i would say is there have been no false alarms at all except if using the radar detector in built up areas - to be honest i switch it off mostly and only user GPS & Laser.
Cheers for that, i think that your info has only proved that the origin B2 is the one i should go for, if you're turning the radar off in built up areas where i do 90p/c of my driving then it would be pointless buying the snooper, plus of course i could always get the radar addon for the origin later if i change my mind
Please see the last reply in this thread:
