The Workshop => Audio / Security / Electrical => Topic started by: Barney Bear on January 13, 2009, 09:21
Title: door speaker
Post by: Barney Bear on January 13, 2009, 09:21
I have done a search about this but as yet found no clue to the fault ...
lots of helpful advise on how to change for better units   s:D :D s:D
Problem I have is one speaker keeps cutting on and off ...question... has anyone had the same problem and if so is it the speaker or the head unit
or is it time to bite the bullet and replace the whole lot   s:lol: :lol: s:lol:
Title: Re: door speaker
Post by: onion86 on January 13, 2009, 13:07
If it keeps going on and off randomly I'd hazard a guess at it's the wiring, probably on the speaker end it could not be connected properly, or the wire might be broken somewhere and keeps disconnecting/reconnecting.
If you're sitting still in the car with the engine off does it still do it?
Post by: wbarrwebster on January 13, 2009, 14:05
Hi,
Suggest it's the wiring, if you can be bothered, get to the back of the Head Unit, by hook or by crook, swap the wiring connetions  from the problem speaker to the good side, if the problem persists on the previous good side,  you know it's the wiring.
More likely to be a dodgy wire from the Head Unit at one of the connections.
Hope this helps.
B
Post by: Barney Bear on January 13, 2009, 15:38
Thanks for the speedy advise   s:D :D s:D
all sorted now, well for a while turned out to be the connection on the back of the head unit
lot of stuff been connected in by Mr T when they put the parrot and TNS system in
Never been impressed by their SN think its time to pull it all out and go for a decent head unit and speakers
at least the sounds are good to go   s:lol: :lol: s:lol:
