The Workshop => Audio / Security / Electrical => Topic started by: Anonymous on August 10, 2009, 13:05
Title: Getting Cables from Battery to Passenger Compartment
Post by: Anonymous on August 10, 2009, 13:05
Hello
I need to get cables direct from the battery (about 10amp) from the rear mounted battery in to the passenger compartment.
Can anyone help? Is there an easy way?
Thanks.
Alan
Title: Re: Getting Cables from Battery to Passenger Compartment
Post by: SimonC_Here on August 10, 2009, 13:29
Through the grommet already in the firewall?
Just take you battery out and have a look with the torch.
You will need to remove the rear bins to get to the other end of it though.
Post by: roger on August 10, 2009, 13:29
There's a hole in the bulkhead behind the battery, which you can also access from behind the passenger seat if you take the bins out. It carries OEM wiring and TBH is a bit difficult to add extra through it in the "proper" place.
However, a cross slit in the surround worked!   s:wink: :wink: s:wink:
Post by: roger on August 10, 2009, 13:30
Beaten again!
Post by: markiii on August 10, 2009, 16:57
Quote from: "roger"TBH is a bit difficult to add extra through it in the "proper" place.
thats because the wires run through individual channels inside teh grommet
Post by: MR 2ster on August 12, 2009, 00:13
As I discovered this weekend with a sub instal   s:roll: :roll: s:roll:
Post by: philster_d on August 12, 2009, 10:16
you can poke the wires through by taping them to a small screwdriver or a length of wire coathanger.
phil
Post by: markiii on August 12, 2009, 10:20
Quote from: "philster_d"you can poke the wires through by taping them to a small screwdriver or a length of wire coathanger.
phil
through teh outside of teh grommet yes
through the centre no
