Hey all,
Recently bought Stargazers old Focals off him (cheers mate!)... spent yesterday stripping the door bits and sound deadening it all with some cheap roof flashing tape (thanks Wickes!) and making the MDF spacers.
Anyways, upon hooking one side up and wiring the input/speakers/tweeters into the crossover thing and firing the system up there is barely any sound coming from the tweeter and next to NOTHING coming from the speaker itself... even when pushed all the way over to lhs on the HU all i can really hear is the tweeter... s:evil: :evil: s:evil:
I've changed the input +/- around to make sure i hadnt wired up wrong - no difference. Did the same with the speaker - no difference. I've tried switching the lil inside switch thing from 0 / -3db / -6db and no difference what so ever.
Can any one suggest or shed some light on what i may be doing wrong as I am severely gutted at the moment... Hoping i've missed something somewhere but cant see what... s:cry: :cry: s:cry:
Thanks...
Jim
First of all make sure that you've wired the HU to the same side (LH or RH) as the speakers are wired. In fact try wiring the HU to the LH and RH crossover inputs in turn just to make sure the crossover is correctly labeled. if you've got a meter disconnect the HU from the crossover and check that the wiring is not shorted to ground - all of the crossover inputs and outputs should read open circuit on the meter.
Then try wiring one of the old speakers to the HU output (crossover still disconnected) to make sure that is OK. Then try each of the new speakers connected directly to the HU to make sure they are OK.
Then connect the crossover to the HU and wire the old speaker to each of the crossover outputs in turn to see if they are working.
Sorry it's a bit long winded, but hopefully you'll hit on the problem before you get to the end.
I took the existing audio cables in the door and cut it and rejoined some new audio cable on to that to go into the crossovers "input" so am 100% sure its correctly wired side wise. Didnt go back to the HU, literally used the existing door wire. Cut just before the wire "splits" to feed the tweeter/speaker.
Currently:-
HU -> existing wiring -> crossover (input) -> tweeters
-> woofer
Will do as you suggest and wire the HU directly up to the HU to see if they work...
Hi Jim,
I had them wired at one point using stock wiring to a HU (no amp) and they were quite loud. You must have a wiring prob here. I think you wired the cross over wrong. Try to wire the woofer (not the tweeter!) directly to the input line (stock wiring) and if it sounds okay you got the crossover wrong.
The plastic cover on the crossover, the polarity markings on it face the terminals if you have it on the wrong way the wiring will be wrong.
Top of crossover with terminals on right hand side.
Tweeter +
Tweeter -
Woofer +
Woofer -
Input +
Input -
Bottom of Crossover
Infact until you have the prob solved don't connect the tweeter as you can blow these if they are wired wrong.
Quote from: "stargazer30"Try to wire the woofer (not the tweeter!) directly to the input line (stock wiring) and if it sounds okay you got the crossover wrong.
wired direct from input to focal speaker #1 = barely hear the sound like a tweeter all tinny = cr@p s:evil: :evil: s:evil:
wired direct from input to focal speaker #2 = barely hear the sound like a tweeter all tinny = cr@p s:evil: :evil: s:evil:
Same standard of sound as when hooked up to the crossover.
original speaker = crisp and clear sounding same as the other side (still original)... s:x :x s:x
So I have established that the wiring is ok... s:crazyeyes: :crazyeyes: s:crazyeyes:
I've no experience as to how crossovers work. Are the speakers special ones that only play when wired up to the crossovers...?
Have disconnected active sub to see if that was interfering in some way shape or form and no difference at all again. Not a happy bunny.
Please help s:( :( s:( I literally can NOT see what or where the issue is. Gutted.
Jim
This is really weird, I'm starting to clutch at straws now but can you tell me do you have an after market head unit or is it a standard one. I am thinking either;
A) The standard HU just can't drive them, I know the standard speakers have a silly low impedance at about 2 ohms, the Focals are 4 ohms so maybe the standard HU is not powerful enough? Long shot as I know both the pioneer and kenwood aftermarket units I have had drive them no problem.
B) If you have the other channel untouched, maybe the HU is seeing the different resistances on the left vs right channel and that's doing it. Again unlikely but I never tried one stock and one focal before.
* EDIT * brain wave, another long shot but when you tried them did you put the door card on? If the focal's are too close to the grill (ie the baffle you made is too thick) they can't move properly and will sound utterly crap, but they'd also rattle the crap out of the door card too!
Jim, are you sure you haven't just taken the feed that went to the original tweeter? That would muck the sound up.
I'd suggest wiring with decent cable from the speakers to the crossover, that should eliminate anything odd with the wiring as long as its all hooked up right.
Quote from: "JiMR2"I've no experience as to how crossovers work. Are the speakers special ones that only play when wired up to the crossovers...?
Jim
All the crossover does is separate the high (treble) from the mid/lows (Bass) from the input source, hence why its called a crossover. At a certain frequency the sound crosses over to the tweeter. Now the Focal's have what's called a passive crossover, ie it requires power from the sound channel to do its job so you loose a bit using them, but honestly not that much. The mid range speaker can be wired directly without the crossover, it would be a fraction louder but then its trying to produce highs its not designed for so it won't sound as good. The tweeter must not be wired directly without the crossover it would blow most likely.
The Focals are rated at a nominal power of 60w RMS, thats more than an after market HU or standard MR2 HU puts out, they are about 14W RMS. So the speakers will sound a bit more tinny/sharp than the standard paper speaker as the focal mid bass speaker needs more power to work. But like I said I ran them from an aftermarket HU and when combined with an active sub to do the low bass they sounded good, much better than standard speakers.
Last thing, on the crossover, knock the tweeter switch to -6db to soften it down. On your graphic the Treble/Mid should be flat, these speakers don't need them lifting like a standard speaker, if anything in your case they need more bass.
Running a pioneer 3100 dvd double din thingy
door cards not on s:( :( s:(
Quote from: "loadswine"Jim, are you sure you haven't just taken the feed that went to the original tweeter? That would muck the sound up.
that could well be the case Nige but the standard speaker on the same wiring sounds good as gold??? the input just went into the tweeter then back on itself sort of and back to the speaker... I just cut before the tweeter and used this as the input???
The incredibly technical drawing below shows the intricate wiring that i've used Nige - a picture speaks a thousand words;
(http://i1037.photobucket.com/albums/a456/ganglyjim/MR2%20Proj/speakers.jpg)
Quote from: "JiMR2"Quote from: "loadswine"Jim, are you sure you haven't just taken the feed that went to the original tweeter? That would muck the sound up.
Yes this won't be it I'm afraid the stock setup uses a cheap capacitor on the tweeter frame itself to filter lows out. The feeds to both the stock mid and tweeter are the same.
Quote from: "JiMR2"Running a pioneer 3100 dvd double din thingy
Pioneer AVH-P3100DVD 5.8-Inch In-Dash Touchscreen Double-Din DVD Multimedia A/V Receiver = MOSFET 50 W x 4 amplifier
Same as most after market HUs, 50w PMPO is ~ 14w RMS, thats not brilliant but it would drive them.
I'd be surprised that the HU could not drive the new speaker if it has a higher impedance. With the new speakers connected to the HU does the sound (1) get louder progressivly as you increase the volume or (2) just get to a level and stay there. If it's (2) then it's likely that the HU is current limiting because it doesn't like the characteristics of the speakers. If you wanted to make sure the speakers were OK, you could try connecting them to your HiFi, DVD player or whatever, although I appreciate that removing them from the doors may be a pain. It would also be worth making sure that neither speaker connection is shorted to earth, either by checking with a meter or just connecting one of the speaker wires only in turn to the HU. In this case if the sound gets louder then theres a short. Or if you are going to remove them from the door, then connect the speaker direct to the HU.
Jim,
Not meaning to sound silly here but you did try cranking up the volume on the HU didn't you? You mentioned pulling the balance far over to the focal, but if the volume was set at a comfy level for the stock paper speaker thats no where near the power level the focal (or any good speaker) needs to work, it would be much quieter and tinny.
David
Just tried crankin it up - normally get to 16 with the stocks and dont push it higher as much higher and it sounds as though the speakers will blow. Got the focal up to 21/22 before id distorted to hell... nice n loud but no bass coming from the Focals what so ever...
Almost like i've got a real big set of ipod head phones in the door on full whack... Usher was warbling... Usher doesnt warble... unless its through this Focals...
Back out to the car and ill try and re-re-re-re-re-re-re-wire them back into the crossover again to make sure i've not got the + / - the wrong way round...
Well just tried re-wiring the wires.
And Usher is still warbling like a trooper...
Quote from: "cclarke99"does the sound (1) get louder progressivly as you increase the volume
Yeah the sound gets louder, no bass and tinny as a good un. Gets to around 20 before sounding distorted. stocks make 16 before sounding iffy. But the stocks sound nice n bassy and half decent compared to the focals as it stands.
I haven't even bothered putting the panels on yet since stripping the doors off. Tested em after wiring in to make sure they worked and low and behold they sounded awful so left the panel off until resolved... That was Sunday s:( :( s:(
Right, now we are getting somewhere! phew.
Jim I think the Focals are actually working correctly. The Focals will produce high tones and mids far better than the stock paper speakers. Those aluminium tweeters when amped and turned up can produce ear splitting treble s:evil: :evil: s:evil: What they won't do is produce good bass because;
A) You don't have them amped, bass needs lots of power to do.
B) You don't have a good volume/enclosure in the MR2 doors for it. (unless you covered the whole outer door panel and door card with flashing)
C) the speaker size is too small for deep bass
Even if you amp them (and you should) you'll only get so much bass out of them because of the above, and if you try to feed them more bass using the graphic your door cards will rattle like crap (I've tried on both the focals and my rainbows)
Your better off setting your HU to filter out the bass to the focals and send it only to your active sub, that will allow the focals to work at higher volume without distorting. At the moment they are distorting as your HU is under powered for them. By cutting the bass from the front HU output your taking some of the load off it.
My current setup I'm running rainbow SLX265s, JBL 4 channel Amp and a cheapy £14 sub. The rainbows are £150 a set and they sound tinny when used without the sub. The focals sounded about the same but were a bit more harsh on the tweeters. I can use the amp and graphic to whack the bass up and it works but then I get rattly door cards. So I've set mine up with the bass at 0db (flat) to the rainbows and the sub doing it instead. It sounds pretty good IMO.
Hi David! thanks for the suggestions below mate, will try that when i get in! s:) :) s:)
I have a 2ch 250w amp somewhere, what would be best - active sub or the 2ch w/ the focals...? Assuming this works that is! s:) :) s:)
Quote from: "JiMR2"Hi David! thanks for the suggestions below mate, will try that when i get in! s:) :) s:)
If you can wire it in I'd use both the 2ch amp and the active sub. The amp will certainly make the focals sound better but they won't do bass as good as the sub even with the amp. Assuming your HU has front and rear RCA outs thats the way to go for sure.
I had my door cards off today to sound dampen the doors with flashing tape. I had done this when I first installed my speakers and to be honest it made them rattle less but made no difference to the sound quality. First time around I just deadened the area behind the speaker and around it. Thats not enough in the MR2 it seems. What I did today is peel back the plastic vapour barrier and use wide flashing tape to cover the three main holes in the door and a few of the smaller round holes. So effectively there are no large holes any more allowing the air/sound behind the speakers to escape through.
I tried it out expecting a small/subtle difference at best and was blown away. The bass response from the doors is much better and the harshness I get on some music is much reduced. s:D :D s:D s:D :D s:D s:D :D s:D s:D :D s:D
