The Workshop => Audio / Security / Electrical => Topic started by: manchestermatt1986 on May 29, 2011, 23:01
Title: Sound deading?
Post by: manchestermatt1986 on May 29, 2011, 23:01
Stargazer has a thread on at the min showing his build and sound deading, I just wondered. What people have done, used and found as I am about to do my front speakers. I have used dynomat I'n the past but it's so expensive
Matt
Title: Re: Sound deading?
Post by: markiii on May 30, 2011, 00:00
Flashing tape is fine but you need to do the inside of the door panels, not the way he did
Post by: DannyN on May 30, 2011, 00:08
Did a load of cars once at the ding day.  Just used flashing tape from B&Q.
I removed the door cards, then carefully peeled off the plastic liner and kept it for reapplying later then coated all the inside of the door skin with the flashing, then put the plastic liner and the doorcard back on.
A tip is to roll out the flashing tape fold it in half and then cut so you get a piece for each door
Post by: stargazer30 on May 30, 2011, 08:31
Quote from: "markiii"Flashing tape is fine but you need to do the inside of the door panels, not the way he did
I did just didn't photo it.  Well I did behind the speaker, not the whole inside, thats overkill for a soft top IMO.
Post by: manchestermatt1986 on May 30, 2011, 17:56
Am i correct in thinking that the flashig tape goes on the rear side of the actual panel where the otherside is outdoors of the car? Do you have to completely cover the door skin? When i looked at dynomat they seemed to just put it where the actual speaker is
Matt
Post by: markiii on May 30, 2011, 19:33
To do it you do the whole inside of the outer panel
I even did 2 layers and no it's not overkill, it works
Post by: DannyN on May 30, 2011, 20:36
Quote from: "markiii"To do it you do the whole inside of the outer panel
+1
The rolls I got did about 1 and 3/4 coats of each door
You'll notice the difference just by closing the door, it closes with a much more satisfying clunk
Post by: CpnSpankyPantz on May 30, 2011, 21:07
I'm about to do this, does anyone have any guidline pictures?
Post by: manchestermatt1986 on May 30, 2011, 22:26
Quote from: "DannyN"
+1
1and 3/4 each door? how much does this stuff weigh? If it is the stuff im thinking of it looks like a roll of black thick squidgy stuff?
Matt
Post by: stargazer30 on May 31, 2011, 10:07
I suspose it depends on what your trying to acheive with the sound deadening.
In my case I was after improving the audio, so I used the deadening to create an enclosure mostly, ie cover the holes.  This makes the most difference, and I speak from a heck of a lot of experience and installs on various cars here.  If you want to try to eliminate road noise as well then the more the better and do the whole door.  It obviously improves the sound a bit more as less road noise to polute it.
Im my case I didn't do this, I wanted to keep the weight down and to be honest its a soft top so road noise is a necessary evil. So IMO and thats what it is an opinion its overkill.
** EDIT ** Op if you do go at it banzai style with the flashing tape, be careful not to cover the drain holes at the bottom of the door!
Post by: DannyN on May 31, 2011, 10:14
This is what we used on about 10 cars at one of the first ding days
 m http://www.wickes.co.uk/hi-tack-flashin ... vt/243010/ (http://www.wickes.co.uk/hi-tack-flashing-strip/invt/243010/) m
It makes a huge difference doing the door skin to both the daily drive and the stereo quality
Post by: manchestermatt1986 on May 31, 2011, 23:22
Quote from: "DannyN"This is what we used on about 10 cars at one of the first ding days
Yea, that's what I thought it would be. My friend bought some years ago to do a del sol. Wondering whether to do the whole inside door or just cover the holes?   s:? :? s:?
Post by: stargazer30 on May 31, 2011, 23:53
Quote from: "manchestermatt1986"Yea, that's what I thought it would be. My friend bought some years ago to do a del sol. Wondering whether to do the whole inside door or just cover the holes?   s:? :? s:?
No harm in covering the holes, seeing if your happy with the sound quality and if not add an extra layer and do the full door.  Flashing tape is cheap enough.
Post by: markiii on June 1, 2011, 00:36
The whole point is to stop the panel resonating
Covering holes doesn't really achieve that
Post by: manchestermatt1986 on June 1, 2011, 02:28
Well I'm I'n the process of purchasing some lambo doors of serina and I'm wondering what effect the extra weight will have on the struts. I know lambo doors aren't everyones taste but I like them and think they look great on the mr2 as the doors are a perfect shape.
Post by: AmeR on June 1, 2011, 08:50
If you're sticking them on Matt I'd wait until you have done them and see how responsive they are. Wouldn't have thought it would add much weight to it though.
Going to put some more on mine next time I have the panels off I think although mine seems to be ok
Post by: ekimq on June 1, 2011, 08:53
Yep, fit the doors and then just drop the roll of tape inside and if the door still opens then you know it'll work when you apply the tape.
Best £15 I ever spent on my '2   s:lol: :lol: s:lol:
Post by: AmeR on June 1, 2011, 08:55
Quote from: "ekimq"Yep, fit the doors and then just drop the roll of tape inside and if the door still opens then you know it'll work when you apply the tape.
Good idea!!
Smart ****!!  s:lol: :lol: s:lol:
Post by: stargazer30 on June 1, 2011, 12:18
Quote from: "markiii"The whole point is to stop the panel resonating
The parts that resonate are the plastic door cards and the thin plastic water proof menbrane.  The metal is not a problem except near the speaker itself.  Even with just the holes covered I can have my amped speakers running full belt and I get no nasty resonation from the door cards now and it sounds great.
But for the sake of argument Op just cover the whole door!
Post by: markiii on June 1, 2011, 12:26
you didn't line the plastic door cards either, so still failed to address the issue
Post by: stargazer30 on June 1, 2011, 13:21
Quote from: "markiii"you didn't line the plastic door cards either, so still failed to address the issue
Mark, my doors don't rattle anymore so I'm pretty sure I did.  I have no issue with my install (well except the sub but thats another story).
Post by: DannyN on June 1, 2011, 13:32
I would definitely put the plastic liner back.
It's easy enough to peel off carefully as it leaves sticky stuff on the door and the plastic making it easy to put back in place and push together to stick back on
Also be careful not cover the drain hole at the very bottom of the door as that's to let the rainwater back out. You don't want to trap it and then try to work out why your door is sloshing  s:lol: :lol: s:lol:
Post by: markiii on June 1, 2011, 14:52
Quote from: "stargazer30"
they might not audibly rattle they will still resonate
Post by: Chris H on June 28, 2011, 19:06
hi,
   have just sound deadened my doors today and installed new speakers,
got flashing tape from wickes,1 roll 150mm by 10metre's length,£10.99.
no more door rattles and fantastic sound.
chris
Post by: manchestermatt1986 on June 29, 2011, 00:43
Quote from: "Chris H"hi,
chris
did you cover the entire inside door panel?
Post by: Chris H on June 29, 2011, 12:04
hi matt,
          completely covered the whole of the door skin,firstly removed the polythene,
although one of my doors does not have this on,then covered the lot,actually thinking
about doing the door card itself next,well for a tenner you cant go wrong.
chris
