With all the posts on here recently about dead engine's was wondering how many of us have driven say over say 60,000 with no real problems. Also could be an idea to say how hard you drive the 2 and the truth about how may services you have. Also which engine version
MR2 Silver - Register November 2000
Full Service - Current Milage 55,000
Only engine problem, faulty exhaust rear pipe, changed under warranty (Design Fault)
Darren
That makes me feel slighly better, but only 1 post since yesterday, thats bad if you are the only "1". lol
well benvic went through 2 engines IIRC, but is no longer a member so you won't be hearing from him.
My manifold just got replaced due to cracks appearing in teh pre-cats. hopefully caught in time as no material had actually come away at that point.
I'd say that not many people will have done over 60000 in the 4 years that the car has been available - unless of course you're someone like SteveJ who seems to do about 10000 every few months!! s:roll: :roll: s:roll:
I have so far done 10000 miles in both of my roadsters with no engine problems what so ever.
Mileage in my cars (roughly)
Silver 'Y' - bought with 9500 miles June 2001, sold with 58,000 miles April 2003
Black '03' - bought with 0 miles April 2003, swapped by Toyota with 14,500 miles November 2003 - please note for ~5months of that I didn't have the car - it was languishing at various Toyota dealers or the tech centre s:evil: :evil: s:evil:
Blue '53' - delivered November 2003 (see above) with 0 miles, to date 15,200 miles
Current mileage is approx 3,000 per month (and expected to rise s:? :? s:? )
So far (touch wood) I haven't had any engine problems and, as most of the regulars on here will attest to, I don't drive the car slowly s:twisted: :twisted: s:twisted:
22 K miles on a 2000 reg and no problems apart from a blocked 4th injector but replaced under warrenty
24K on a W reg 2000 and no problems at all. My worry is that it is getting to that milage where all the horror stories start to happen s:shock: :shock: s:shock:
Needless to say, the belt tensioner is rattling, but that is it. And I have become SERIOUSLY vigilant about checking oil and water now too.
9k s:oops: :oops: s:oops: s:oops: :oops: s:oops: s:oops: :oops: s:oops: on a 2000 X Reg.
No engine problems (touch wood) so far... and serviced regularly as per the guidelines.
Sundance s8) 8) s8)
QuoteNeedless to say, the belt tensioner is rattling, but that is it. And I have become SERIOUSLY vigilant about checking oil and water now too.
What!!!
You need to check your water!? s:shock: :shock: s:shock:
Where is that, i couldn't find it when i first got my car last year and presumed it was self contained!
Sky, I only check it as a matter of precaution. Nothing to worry about. Its part of a habit I formed when I got water leaks on my old Minis and I have never really got out of the habit, especially when you have to pay out for new engines......... s:roll: :roll: s:roll:
The water bottle is on the left hand side of the engine bay, towards the back. Should be filled with a pinkish fluid (MrT's "liquid gold" called Forlife). Mine has NEVER changed from full, but I like to look all the same.
Mines a black 2000 X with just over 20K on the clock and I've had no engine problems at all.
I try not to worry about it. I've had two Rover K Series cars and done 45K and 15K in them without any problems. That's an engine with a real repution for going pop due to HGF.
I'd never let something that affects a small percentage of cars put me off having the one I want.
Fingers crossed,
Paul.
hey I have a 52 plate and it has done 16k and no problems ,... touch wood!
'02 plate, 26k, no engine problems at all, pre-cats fine.
99 import, 45k when i bought 8 weeks ago now 52k
dont baby the 2 at all in fact im quite hard on the poor thing - just ordered the o2 sensor socket to check precats etc, changed oil but happy motoring so far...touch wood
Oct 2000 X-reg - 51000 miles, with absolutely no engine reliability problems at all.. and although most of those miles are motorway cruising at approx a constant 3800rpm, I don't baby it the rest of the time! s:wink: :wink: s:wink:
Tim
if you look at spyder chat, in the maintance section, it seems to me that most engine fairlures have happened on a 2000 model.
Mine: 2000, 19K miles. No problems so far..., although the engine does sound a little rough to me - could just be the pre-tensioner belt getting a bit loose - i hope!
Well might as well add mine as an 'outlier'
2003
Driven with respect, occasional blast
6000 miles
Pre cat failure, gulping oil, major loss of performance
Caught early, seems fine now!
Peter also got through 3 engines if memory serves?
Well mine won't make too good of a read, here goes:
Currently 42,000 miles Y Reg (2001) (serviced as per manual from new)
Changed under warranty:
Most of the gearbox (was making a grinding noise)
V-Belt Tensioner
Precats + Main Cat
Pending:
Piston knocking about in cylinder #1 (prob due from incompetent dealer changing cats and not checking for engine damage at time).
Due for a engine strip and examination on 14th April.
I used to do mainly motorway miles, but when I was off the motorway I'd drive it hard. Took out extended warranty this March (Thank God - considering the recent engine probs).
Sam
Quote from: "MRMike"Well might as well add mine as an 'outlier'
2003
6000 miles
you say you have a 2003, 6000 miles and the precats failed? s:shock: :shock: s:shock: s:shock: :shock: s:shock: Blimey!
The answer is go turbo no more less reliable and sooooo much FUN..... s:wink: :wink: s:wink:
Indeed! I posted about it a while ago..it wasn't breaking up as has been noted previously, it had cracked down the centre apprently. Though it still consumed oil and had a loss of back pressure and performance, which I'm still not sure about. I'm keeping a watchfull eye on it for the time being
Quote from: "SteveJ"Black '03' - bought with 0 miles April 2003, swapped by Toyota with 14,500 miles November 2003 - please note for ~5months of that I didn't have the car - it was languishing at various Toyota dealers or the tech centre s:evil: :evil: s:evil:
See what I mean!! s:lol: :lol: s:lol: 14k in about 4 months - about 3x the national average innit?! s:shock: :shock: s:shock: s:lol: :lol: s:lol: s:lol: :lol: s:lol:
14k on a 52 plate.
Runs sweet as a nut (where did that saying come from?)
Only noise at present is what sounds like clutch thrust bearing whine.
My first one was an 01 'Y' plate SMT, which did 32k miles in 26 months (probably mostly motorway s:oops: :oops: s:oops: ), serviced to schedule. Paint blemish on driver's door, misting headlamps & Sony radio/cassette/CD (faulty volume control) sorted under warranty, otherwise no problems. It was starting to show signs of the infamous clonking noise from the front when I chopped it in, but the front tyres were well worn on the inside edge, so might have contributed to that problem.
Currenty running an '03 SMT (03-plated), now 9 months with a 10k service booked on the 19th of this month. Gearbox went AWOL after 3 days (less than 200 miles), but fixed by the nearest dealer when the problem arose, and on the same morning. No trouble since then ... touch wood. Most annoying problem is the rattly dash. The '01 was rock solid in build quality, quieter than our sensible hatchback, whereas this one seems to have been built on the MGF line for some reason s:roll: :roll: s:roll:
As to my driving style - everyone on here will say I drive like a girl, but I don't stint with either pedal when the opportunity arises, it's just I'm not a dab hand at all the sideways stuff :-) :-) :-) Plus, it's my daily drive, so my thinking is a little respect for the machinery should help with reliability and longevity. Having said that, I only check fluids and pressures every couple of weeks or so - so it's not like I'm mr. paranoid pit crew here!
Y reg - 19k no problems @ all ( watch this space )
I've got a 2000 with 59k (there must be someone with a higher mileage!?)
I had the belt tensioner done at 35k(ish) but apart from that it's been fine engine wise. (Touch wood)
dave.
