Anyone know how easy it is to turn on/off the passenger air bag? I know some cars you simply turn a key, just wondered if anyone had done it in theirs (in case i need to take my baby neice out). Im guessing the dealer could do it, but wondered if there was a nice easy "do it yourself" way???
I was only thinking that the other day!..honestly!
Any ideas anyone?
you planning a family then! s:wink: :wink: s:wink:
Yeah snip the wires s:wink: :wink: s:wink: LOL
Actually i dont know i know there is a way as it needs to be disabled for baby seats!
Planning a family oh dear you lot are old LOL s:wink: :wink: s:wink:
Im still loseing my V plates s:oops: :oops: s:oops: Joking guys joking solid GF for a few years s:wink: :wink: s:wink:
Don't think you can on the 2 sorry.
As I recall there's a whole section on baby seats in the '2 manual... don't recall what it says, but there's almost as much in there about that as connecting the rear windscreen heating cable (which is to say, quite a few pages). I'd guess it would answer your questions.
RTFM - LOL!
I had really brief read through the appropriate manual section (and sorted out my rear window heater connector while I was at it).
Doesn't look like there's any way of turning the passenger airbag off. So they don't recommend rear facing sprog seats (mainly 'cause it's likely to kill said sprog/sprogette), nor that you use a sprog seat at all, unless it's absolutely necessary (sort of like saying don't drive you car without brakes... unless you have to!). It then goes on to recommend sliding the seat back as far as possible if using one.
There's lots of detail on the types of seats for different weights, ages and so on, detailing which should and shouldn't be used etc.
That said Kris, I doubt your baby neice would appreciate the handling and performance (let alone the sporty looks) of your '2, so perhaps you're wasting a little effort? s:) :) s:)
All details contained herein are a rough outline of the data provided by Toyota in the MR2 Roadster operating guide. The above details are not intended to replace the guide, nor be a definitive authority. Death or injury to any individuals following any of the advice given above is not my responsibility. If you're going to put small children in your car, read the manual first and follow it's advice fully.
Quote from: "phil4"All details contained herein are a rough outline of the data provided by Toyota in the MR2 Roadster operating guide. The above details are not intended to replace the guide, nor be a definitive authority. Death or injury to any individuals following any of the advice given above is not my responsibility. If you're going to put small children in your car, read the manual first and follow it's advice fully.
Or buy a SUV for the school run.....
On my 2 across the water, there's a switch in the glove box that fits the ignition key that can deactivate the pass air bag
Rex
Quote from: "rexster"On my 2 across the water, there's a switch in the glove box that fits the ignition key that can deactivate the pass air bag
Rex
Yes Ive read about this. My German one doesnt have this switch, but I dont care as we dont have any rug rats, just a demented cat who sh1ts its self every time it goes in a car, so its banned from the 2. Mind you at least with the roof down the smell goes quicker! s:roll: :roll: s:roll:
Thats just your driving Victor s:o :o s:o
Try strapping the feline to the rear engine rack, the shit should just hit the car behind then s:lol: :lol: s:lol:
Rumour has it that disconnecting the cable under the seat (that is partly for the no-seatbelt light) will disable the airbag, but I don't think it is 100% proven...
Quote from: "Slacey"Rumour has it that disconnecting the cable under the seat (that is partly for the no-seatbelt light) will disable the airbag, but I don't think it is 100% proven...
Loom to the drivers seat and the passenger seat looks no different unless you can disable your air bag as well when disconecting the seat belt sensor??? But i dont think they would do that incase the loom broke down and failed you would have no air bags and a sore head s:roll: :roll: s:roll:
Quote from: "Buster"Loom to the drivers seat and the passenger seat looks no different unless you can disable your air bag as well when disconecting the seat belt sensor??? But i dont think they would do that incase the loom broke down and failed you would have no air bags and a sore head s:roll: :roll: s:roll:
I agree Buster, but our yankie freinds over at Spyderchat are pretty convinced that the airbag is disable if you pull the underseat connecter... s:? :? s:?
Yanks engoth said LOL
Only joking my USA chums s:lol: :lol: s:lol:
Quote from: "krisclarkuk"Anyone know how easy it is to turn on/off the passenger air bag? I know some cars you simply turn a key, just wondered if anyone had done it in theirs (in case i need to take my baby neice out). Im guessing the dealer could do it, but wondered if there was a nice easy "do it yourself" way???
I had to disable mine for the same reason. Quite simple - disconnect the connector under the seat (I found this out after a local dealer messed around with it and forgot to reconnect it!!).
Quote from: "Peter Laborne"I had to disable mine for the same reason. Quite simple - disconnect the connector under the seat (I found this out after a local dealer messed around with it and forgot to reconnect it!!).
Peter, as per my earlier post has this been proven? Did the dealer confirm the airbag was disabled? I don't have a need to disable it, but when my car arrived from Denmark the passenger seatbelt light didn't work - I fixed it three months later when I saw a thread on Spyderchat discussing this same topic and re-connected the wires! I was a bit miffed (if it does deactivate the airbag) to say the least, I'm glad nothing happened when I had passengers in the car! s:shock: :shock: s:shock:
Surely there's enough room in the bins behind the seats for a baby seat, no airbags in there s:lol: :lol: s:lol:
It wont be much of a problem soon as she will start to use a forward facing seat - its more of in an emergency if i need to take her anywhere then i would not want the airbag going off - cheers guys for the info.
did anyone find a solution to this?
With a baby 7 weeks away I'm looking at buying a fun car to run alongside the family motor. But it would be ideal to find a fun car I can at least take my baby son/daughter out in every once in a while.
Do even the new 04 models not allow you to deactivate the airbag by a dealer approved switch ????
Has the MR2 always had a passenger air bag (seem to recall thinking older versions didn't have the 'luxury' of passenger air bag??)
Quote from: "che6mw"Has the MR2 always had a passenger air bag (seem to recall thinking older versions didn't have the 'luxury' of passenger air bag??)
All EU models have it. The japanese base model doesn't have it.
About the passenger seat sensor, it has nothing to do with the airbag! It's just a seatbelt reminder.
US models have a switch in the glove compartment for the passenger airbag. I'm sure you could get that from US and install it into your car.
