The Workshop => Performance Related => Topic started by: Anonymous on April 14, 2004, 10:41
Title: Greddy E-manage
Post by: Anonymous on April 14, 2004, 10:41
Hi all,
Has anyone here tried to fit a Greddy E-manage on an MRS turbo?
Paul
Post by: mph on April 14, 2004, 11:20
Yep. Several. I think everyone but me actually! All successful and happy. People to hassle include: mr-s_turbo, DAZ400 & perry190...
Post by: Anonymous on April 14, 2004, 13:29
Cheers for that, has anyone got an ECU pinout diagram for an MRS? Its not listed on the E-manage installation manual...
Post by: GSB on April 14, 2004, 13:30
I've got one on paper I can scan, or I think theres on on SC.
Post by: Anonymous on April 14, 2004, 13:31
SC? I'm new to this forum...
Post by: GSB on April 14, 2004, 13:32
SC = Spyderchat, our US based equivalent.
Here it is:
 m http://www.spyderchat.com/phpBB/viewtopic.php?t=425 (http://www.spyderchat.com/phpBB/viewtopic.php?t=425) m
Post by: Anonymous on April 14, 2004, 14:29
I can help   s:D :D s:D
What wiring harness' have you got? ie have you got just the e-manage unit, or the ignition snd injector harness aswell?
Post by: Anonymous on April 14, 2004, 17:24
I haven't actually got it yet but will have in a couple of weeks time, I'll be using the optional igntion and injector harness yes.
Post by: Anonymous on April 14, 2004, 17:41
Well here's a start  m http://members.cox.net/dbatchelor2/eManage%20wiring.rtf (http://members.cox.net/dbatchelor2/eManage%20wiring.rtf) m
What turbo is on or going on the '2? Are you tuning it or is the e-manage pre-programmed? Infact just give us more details on the install   s:D :D s:D
Post by: Anonymous on April 16, 2004, 08:19
Thanks for that, much appreciated.
Sticking a PE turbo kit on amongst other things, just getting all the bits together at the moment, I'll let you all know when its done....
Post by: MR-S Turbo on April 17, 2004, 11:47
I am just about to fit a Pre-programmed one to my PE Turbo install.  I have both Injection and ignition harnesses.  Is it easy to do?
Post by: Anonymous on April 17, 2004, 12:12
Where did you get a pre-programmed one from? US or Japan I presume? If so I dont think thats a good idea unless your going to fine tune it of course?
Post by: Anonymous on April 17, 2004, 13:38
I got mine from the states. It works fine pre-programmed. Now i've got the wideband in i have now tuned it for the right amount of fuel. It's nice to have some maps in there atleast to start with.
Is it easy to fit? Well i'll say yes but it's obviously on how good you are with electrics. It involves cutting and splicing wires at the ecu so it can be a bit scary to start. A few have fitted it now so help is here if you become stuck.
Post by: Anonymous on April 17, 2004, 23:10
Yep, pretty good the E-manage for the money, I've fitted a few of them now to various different cars with good results on all of them, looks like I'll be sticking one on my MRS when I bolt my turbo on....
Cheers for your help
Post by: MR-S Turbo on April 19, 2004, 18:43
Has anyone got clear wiring diagrams for fitting this unit?
Post by: Anonymous on April 19, 2004, 18:54
What about what you sent the other day?
Post by: Anonymous on April 19, 2004, 18:58
2 different people with same author name i'm afraid Whifbitz.
I haven't gone mad!!!!  s:wink: :wink: s:wink:
Post by: Anonymous on April 19, 2004, 19:04
I see, said the blind man.
Post by: Anonymous on April 19, 2004, 19:16
Quote from: "Whifbitz"I see, said the blind man.
  s:lol: :lol: s:lol:    s:lol: :lol: s:lol:
As said, MR-S Turbo, is the link to the wiring of the e-manage that i posted above not clear enough?
The only thing it doesn't show is the injector harness. This is the same block as the injector harness, using pins 1,2,3,4 for the same corresponding cylinders. These wires are spliced into, not cut.
Post by: MR-S Turbo on April 19, 2004, 19:42
QuoteThe only thing it doesn't show is the injector harness. This is the same block as the injector harness, using pins 1,2,3,4 for the same corresponding cylinders. These wires are spliced into, not cut.
Im sorry to sound dumb but what colours are these wires? for the injector harness and The Toyota colours.  I need to get as much info on this before i start chopping wires.   s:? :? s:?
Post by: Anonymous on April 19, 2004, 20:58
Its easy once you get stuck in....
Post by: Anonymous on June 3, 2004, 17:52
Right, just in the middle of wiring up my emanage. Has anyone got the air flow meter and jumper settings for the MRS handy?
Post by: Anonymous on June 3, 2004, 18:06
Thought you had it done?
Anyway,
Jumpers should all be set as factory default apart from J2, this is short between 2 & 3.
Rotary switches are 4-2-2
Post by: Anonymous on June 3, 2004, 19:00
god this moderator  guys good  s;-) ;-) s;-)
Post by: Anonymous on June 3, 2004, 19:14
Nah, haven't had time, been to busy messing around with my Supra to get on the MRS at all, had a spare afternoon today so I thought I'd better get on with it as it was suppose to be all done for beginning of May!
Anyway I've sorted it now, tried them settings and it all works nicely now.
Going out tomorrow with any luck to do some mapping on it.
Tar
Post by: Anonymous on June 3, 2004, 19:28
Quote from: "perry190"god this moderator  guys good  s;-) ;-) s;-)
I've got a really good map if you have any IC or WI on your '2, if you want a base map to fine tune from?
Post by: Anonymous on June 3, 2004, 21:22
I'm sticking water injection on for the moment yeag so that would be great if you could email it over to me? Something to get me started, who done your map?
Have you got rid of that knock sensor mod that comes with the PE kit?
Post by: Anonymous on June 3, 2004, 21:32
Never even got 1with my kit. As far as i'm told it's a waste of time.
I have a wideband O2 in all the time linked to my profec display. I've done all the tuning myself from an original map i received with my e-manage from MWR. It is good upto 9psi. Just thought though, i've got 330cc injectors in, if you haven't it will not work aswell with yours.
Post by: Anonymous on June 3, 2004, 22:46
Yeah it is poo, causes some strange running problems, gets rid of detonation though!
I'll be able to use the ignition map off it though wont I, I've got a wideband on there so can tune the fuelling to suit. Can you email it over so I can take a look?
Post by: Anonymous on June 4, 2004, 00:24
Post by: Anonymous on June 4, 2004, 09:57
No boost controller fitted as yet nope. Have you got that map handy?
Post by: Anonymous on June 4, 2004, 10:16
Post by: Anonymous on June 4, 2004, 10:24
Yeah I always set my cars up on the road, its gives a more real life situation. Although saying that it could be bad on my license if I ever get caught in my Supra, 170mph are regular speeds in that thing while its being mapped.
Anyway, I've put the charge cooler on the back burner for the mo, it will be done though, just not right now, I've got my hands full with my Supra at the moment, I want to get that all finished off before I start going to town with the MRS. This is all being done in between running a business so time is a bit tight.
My wheels are arriving today, bodykit will be here next week sometime so I've got a few bits to do on it before I get stuck in on the power front.
What type of injectors does the MRS use, low or high impedance? Side or top feed? I've got some 440cc sitting here out of my Supra from years ago....
Post by: Anonymous on June 4, 2004, 10:42
Post by: Anonymous on June 4, 2004, 13:15
I've emailed you the map. Let me know when you get it.
Post by: Anonymous on June 4, 2004, 13:43
Nice one, cheers for that, I'll take a look at it a bit later on.
Post by: Anonymous on June 7, 2004, 18:30
Where did you get your decat pipe from Perry? Was it custom made? Cant find one anywhere...
