The Workshop => Maintenance, Problems & Troubleshooting => Topic started by: Anonymous on November 23, 2011, 18:22
Title: po135 sensor
Post by: Anonymous on November 23, 2011, 18:22
I have had my 2003 mr2 tested as the engine warning light is on and it came back as po135 oxygen sensor how hard is it to do at home and if there is any videos on you tube to show me how, or do i let the garage do it they have said it will be about £250 is that ok. ?
Title: Re: po135 sensor
Post by: K T M Rider on November 23, 2011, 18:57
£250 is a scandalous rip off.
buy this:
 m http://www.ebay.co.uk/itm/Draper-Lambda ... _508wt_700 (http://www.ebay.co.uk/itm/Draper-Lambda-Sensor-Diesel-Injector-22mm-Socket-55540-/150692707919?pt=LH_DefaultDomain_3&hash=item2315fc3e4f#ht_508wt_700) m
and a DOX 0204 from here:
 m http://www.sparkplugs.co.uk/pages/prici ... da-ccp.asp (http://www.sparkplugs.co.uk/pages/pricing/ccp/Denso-Lambda-ccp.asp) m
then read this:
 l viewtopic.php?f=47&t=21462 (http://www.mr2roc.org/phpBB3/viewtopic.php?f=47&t=21462) l
the one you need to replace is on the right (drivers side) in the 3rd picture down - and staring you in the face when you open engine lid. I think you can safely ignore the bit in the guide above about crimping on your existing connector as I'm pretty sure that the new denso one will come with a connector already attached.
If you want to do it cheaper, get a second hand one from D!ck2Ski on here.
