Can anyone tell me which wire behind the instrument binacle goes to the vehicle speed signal/sensor please?
Or point me to a wiring diagram please?
Vinny
Anyone?
You will need to double check this but I think it might be purple.
EDIT: It is violet and white
I need to know the same information tbh as I want to wire my shift light to it so it knows what revs im going, I know you can test for it with a multimeter but its a pain in the backside sometimes
Got some info off spyderchat and I'm fairly sure I know which wire it is now
It's purple and white - once I've fitted my heads up display and it's working I'll post up to confirm s:) :) s:)
That would be mucb appreciated bud cheers.
Nearly got my shift light its just that one wire
Why would you want to connect a shift light to the speedo signal? s:roll: :roll: s:roll:
Quote from: "SteveJ"Why would you want to connect a shift light to the speedo signal? s:roll: :roll: s:roll:
Good point
My car has a gear shift light but it's not worked since I had the car. I'll have a look at that wiring while I'm there and post that too s:) :) s:)
Lol its the tachometer wire im after... just realised wrong name... the revs one
Quote from: "Lippy"Lol its the tachometer wire I'm after... just realised wrong name... the revs one
That's the white wire.
Ive not had chance to look at the wiring on the back of the speedo cluster yet, would it be possable to explain clearer for a noob?
How many plugs are there to the cluster and roughly how many wires? is there a color on the plug or a pin number?
I cant seem to find anywhere that has pictures etc...
View this thread (http://spyderchat.com/forums/showthread.php?46600-MR2-Spyder-Gauge-Cluster-Disassembly-How-To&p=765422#post765422) to see what it looks like.
The tach wire is white on C6
The speedo wire is violet with a white stripe on A5
