The Workshop => Audio / Security / Electrical => Topic started by: Anonymous on January 8, 2012, 00:11
Title: single din facia help!!
Post by: Anonymous on January 8, 2012, 00:11
hi guys only just joined so bear with me if i sound stupid  s:? :? s:?   iv got a 2000 uk spec roadster that came with a sony wx-c570r double din head unit, i bought a single din conversion facia autoleads fp-11-03 but it doesnt fit properly, its tight at the top with an inch to two inch gap at the botom after a bit of modification looks terrible  s:( :( s:(  does anyone know if theres a proper kit for my car? iv only seen them for an import 2002 onwards? any replys will be much appreciated thanks richard...
Post by: AmeR on January 8, 2012, 00:36
Edited to remove stupidity pointed out in the nicest possible way
Title: Re: single din facia help!!
Post by: Anonymous on January 8, 2012, 00:53
would that be from a later model o3 on?
Post by: uktotty on January 8, 2012, 01:32
Quote from: "bulbsubaru"i bought a single din conversion facia autoleads .
Quote from: "AmeR"Auto leads do a single din conversion kit
REALLY??
Maybe read the post before responding?
Post by: Anonymous on January 8, 2012, 09:28
No expert on this as I replaced with a double din. The conversion adapter does it have the hole for the head unit and what it a pocket / shelf to store stuff attached
Post by: VVT-i on January 8, 2012, 10:54
I seem to remember some people had problems with the outer trim piece from the pre-facelift cars not fitting properly with the facia adapters, the solution was to find the trim piece from a newr car and fit it... might be wrong, but I am getting old and senile, but worth mentioning incase this is part of the problem.
Post by: uktotty on January 8, 2012, 12:55
Quote from: "VVT-i"I seem to remember some people had problems with the outer trim piece from the pre-facelift cars not fitting properly with the facia adapters, the solution was to find the trim piece from a newr car and fit it... might be wrong, but I am getting old and senile, but worth mentioning incase this is part of the problem.
Pretty sure Davy is right, I had this issue with mine, you need to get the post facelift surround from Toyota and fit that to the single din conversion.
Do you have any pictures of your install OP?
Post by: Anonymous on January 8, 2012, 17:07
will try to upload some picks tomorow for more help! may have to start again? the car is a pre facelift i think? its a 2000 w reg 1.8 vvti mr2 roadster, it came with a sony double din but the facia wont fit around the new autoleads facia part number fp-11-03 b0012zt1q4   s:? :? s:?
Post by: VVT-i on January 8, 2012, 18:19
You have bought the correct fascia adapter..FP-11-03
(http://budgetcaraudio.co.uk/ds-ebay/products/fascia/FP-11-03.jpg)
I'm guessing that you now have a gap all the way around it. As I said earlier, something tells me it's the trim piece you need to change as described here..  l viewtopic.php?t=6096&highlight=fascia (http://www.mr2roc.org/phpBB3/viewtopic.php?t=6096&highlight=fascia) l  (found after searching for FP-11-03 on  m http://spydersearch.org/ (http://spydersearch.org/) m  along with lots of other info)
If you have the same problem, the long and short of it is... you need the stereo trim surround from the 2003 onwards car as these are different from the pre-facelift cars and will fit the fascia and fill in the gaps making the conversion appear stock, I found the topic where UKtotty had this problem and the new surround trim fixed it.
PM  l memberlist.php?mode=viewprofile&u=14150 (http://www.mr2roc.org/phpBB3/memberlist.php?mode=viewprofile&u=14150) l  as he might have one in his posession.
lol, swear filtr wouldn't let me post the usename.
Post by: Anonymous on January 8, 2012, 19:38
Ive got a facelift HU, but the surround appears to be designed not to be removed.
Plus the new owner will want a surround I imagine. Sorry.
Post by: Anonymous on January 9, 2012, 14:38
mine looks different to the pic above?
Post by: uktotty on January 9, 2012, 15:24
Quote from: "bulbsubaru"mine looks different to the pic above?
Sounds like they sent you the wrong one then!
Got a pic of yours?
Post by: Anonymous on January 9, 2012, 15:32
Think im in the same boat here, so will be needing the adaptor plate and thats all to fit my own MP3 jobbie?
Post by: VVT-i on January 9, 2012, 18:37
You will also need an ISO adapter (ISO - Toyota) to make it plug n play.. so no cutting/joining of wires, around a tenner from ebay.
Post by: 2 of the left on January 9, 2012, 20:35
I found the quickest way to get right facia,surround,adaptors and underslung pocket was to go Halfords and order from them using your Reg number - Once you have all items either fit yourself,use halfords ( they have half price fitting promotion still ongoing) or find a dedicated audio shop to do it!!
Post by: Anonymous on January 9, 2012, 23:52
took some pics earlier but have no idea how to put them on here? have managed to source the facia i need from my local toyota dealer, part number for future ref is 55423-17040-C0 £22.00 + vat  s:crazyeyes: :crazyeyes: s:crazyeyes:   hope this will help others in the same boat  s:wink: :wink: s:wink:
Post by: Anonymous on January 10, 2012, 09:57
Quote from: "bulbsubaru"took some pics earlier but have no idea how to put them on here?
I use photobucket and copy/Paste the Image code straight into the text. Does not use up your allowance also normally.
I have found this, which looks like everything i woud need to instal my single din unit? Ie i dont need any more interior trims?
 m http://www.ebay.co.uk/itm/Toyota-MR2-Ro ... 25654743d1 (http://www.ebay.co.uk/itm/Toyota-MR2-Roadster-Stereo-Fitting-Kit-Fascia-ISO-T2-/160612959185?pt=UK_In_Car_Technology&hash=item25654743d1) m
Post by: uktotty on January 10, 2012, 10:00
I think you still need the fascia
(http://www.freewebs.com/gjgrafix2/Fabrication01.jpg)
Post by: VVT-i on January 10, 2012, 22:31
What I would refer to as the facia is included in the link above, which is the part with the pocket/tray, also included is the ariel adapter and the toyota ISO lead.
To make thins look stock and fit better. you would need what I would refer to as the surround trim, which Russ has posted in the photo above (top piece in the picture) however, the one in the picture is different from mine... facelift model, maybe the one pictured is from a pre-facelift?.. Russ?... which would explain why a facelift surround trim is needed to make it all fit properly and look stock.
(http://img.photobucket.com/albums/v246/cfc/100_3788.jpg?t=1233871146)
The trim surround is the same as what goes around the ashtray too.
Post by: Anonymous on January 20, 2012, 15:54
So i brought the kit from the ebay link i posted above and got it through the post today (3 days) for 14 buckaros...
Bit of messing about to fit but very easy as it came with a detailed fitting instructions for the specific car! this was a great help and i can only give a very positive feedback on the kit itself.
It came with - facia, wite harness/adaptor and arial adaptor (not required) with instruction booklet.
Fitting instructions In brief:
1 - Unclip the two silver plastic end peices from the down beams either side of the console.
2 - Remove 2x phillips screws from behind the plastic end clips each side and remove down beam covers by sliding down and away from console.
3 - Pull out all three heater control knobs and remove 2x silver phillips screws located behind.
4 - Pull off air circulation knob from stalk then pull out control panel facia taking care of clock wires etc.
5 - Undo 4x phillips screws holding original headunit in and pull it out and unplug from behind.
6 - Fit locating brackets (4x phillips screws) either side of hole using instructions (tab C's) only in the same places you removed stereo screws in step 5.leave screws loose for adjustment.
7 - Slide facia into bracket and push until it snaps into place. now tighten 4x screws on mounting brackets.
8 - Now reassemble the side beams, end covers and heater control facia and knobs.
9 - Finally fit single din unit into the new hole provided by the updated facia as per usual installation process, plug and play!....
10 - Remove outer trim from old head unit and clip onto new facia to complete the look.
Mine looks exactly the same as the one pictured above completed, my car is a W reg (2000).
 Happy Dayz......
