The Workshop => Audio / Security / Electrical => Topic started by: Skorps78 on March 7, 2012, 05:35
Title: Sony WX 570R Removal
Post by: Skorps78 on March 7, 2012, 05:35
Hi all
having trouble removing the double din to check aerial lead. I've seen some posts on how to remove but would appreciate some pics if anybody has some please?
The surround seems impossible to remo  s:crazyeyes: :crazyeyes: s:crazyeyes:  ve
thanks
Title: Re: Sony WX 570R Removal
Post by: loadswine on March 7, 2012, 07:13
From memory, I think you have to remove the plastic covering to the console struts on each side, then you can get access to 4 screws on the reverse face of the surround on each side. Also you'll probably need to remove the heater panel just above the head unit as well.
Post by: Anonymous on March 7, 2012, 07:39
At the bottom of the black dotty legs are two silver plastic caps. These just pull off, the button type rivets are a bluff. Needs a really good yank though!
Undo two crossheads behind. Pull off dotty leg covers.
Remove the 3 heater control knobs and slider knob, just pull off.
Undo two screws behind and remove cover.
You can now get to the four crossheads that hold the stereo. Give it a wiggle to get over the cup holders.
Post by: Anonymous on March 7, 2012, 08:44
 l viewtopic.php?f=47&t=17670 (http://www.mr2roc.org/phpBB3/viewtopic.php?f=47&t=17670) l
Post by: Skorps78 on March 9, 2012, 22:37
Cheers guys
