anyone know the part number for the little plastic cover that releases the roof (under the deflector)? It's the bit that says 'pull'!! I just got two screws showing and want to tidy it up!
Thanks,
Viggs
One of the guys with the BGB will know... and I expect quite a few people will be interested in this one! s:wink: :wink: s:wink:
Quote from: "Viggs"anyone know the part number for the little plastic cover that releases the roof (under the deflector)? It's the bit that says 'pull'!! I just got two screws showing and want to tidy it up!
Remove your seats, I bet it's under there s8) 8) s8)
It has a habit of flying off when you slam the top down. Put some two sided foam tape under it to keep it there s;) ;) s;)
So that's what it's for s:oops: :oops: s:oops:
I found it in the glovebox and always wondered what it was !
Crankshaft
No sign of it anywhere!!
s:( :( s:(
and i thought mine was the only one to fall off
thinking might get some of those sticky pads to hold it in better
Seems you can't get just the plastic cover from Toyota, but you have to buy the whole latch. Part number 65904-17011...and apparently that's about $80 in US, pretty expensive, if you only need the plastic cover s:? :? s:?
