the install guide states the follwing connections:-
Red = key off switch +12v
Yellow = Ignition switch on +12v
Blue = ACC or Ignition 2 +12v
Now, looking at Busters wiring post from a few months back (very helpful :-) :-) :-) ) it offers the following wires at the ignition harness
12v white/red & white/blue
Starter red +
Ignition black/yellow +
Second ignition red/white +
Accessory pink/blue +
would I be correct in thinking that I should connect as follows:-
timer yellow to black/yellow ?
timer blue to red/white ?
timer red to white/red ?
ant help from anyway who knows for defo would be much appreciated :-) :-) :-)
it should be black/yellow!
As you want the timer to power up before you turn the engine on so IGN 1 will be fine, this would be the first click on the barrel.
Quote from: "Buster"it should be black/yellow! .
what should???
the wire you want to splice into s:wink: :wink: s:wink: s:wink: :wink: s:wink:
