The Workshop => Audio / Security / Electrical => Topic started by: s12vea on October 16, 2013, 13:05
Title: Show me your sub box ....
Post by: s12vea on October 16, 2013, 13:05
I'm just looking for ideas for a sub box to go behind seats. I've got 2x 10" subs and a 4 channel amp which I'm planning on making a build of some sort.
Just wanted to see what anyone else had done, pictures and measurements would be great also  s;) ;) s;)
Title: Re: Show me your sub box ....
Post by: StuC on October 16, 2013, 13:22
Wasn't Danny sorting something out for you?
Post by: s12vea on October 16, 2013, 14:18
I emailed him a while ago but no reply  s:( :( s:(
Post by: nathanMR2 on October 16, 2013, 14:40
Dont fancy one of these do you??  l viewtopic.php?f=36&t=34566&start=150 (http://www.mr2roc.org/phpBB3/viewtopic.php?f=36&t=34566&start=150) l
Someone has just pulled out
Post by: s12vea on October 16, 2013, 14:43
Thanks for the offer but fancy having some sort of build behind the seats.
Post by: nathanMR2 on October 16, 2013, 14:44
No probs. Just thought id check
Post by: s12vea on October 17, 2013, 19:13
No sign of any pictures yet - somebody help me out.
Post by: Flipside on October 17, 2013, 20:36
What about one of these
(http://img.tapatalk.com/d/13/10/18/ebe2yneq.jpg)
I have the single version
(http://img.tapatalk.com/d/13/10/18/hatequta.jpg)
Post by: s12vea on October 17, 2013, 20:42
I've already got the 2 x 10" subs just need to decide what to do box / enclosure
Post by: Flipside on October 17, 2013, 20:50
Oh ok,  lots of measuring to do then
Post by: s12vea on October 17, 2013, 21:12
Looks like it. Was hoping someone else was going to help me out  s;) ;) s;)
Post by: nathanMR2 on October 17, 2013, 21:32
Have a word with jimr2. He did a pretty good enclosure
Post by: s12vea on October 17, 2013, 22:01
Of course. Will drop him a pm
Post by: Anonymous on October 17, 2013, 22:15
If it was me I would make a panel to replace the bin doors. Then build a box behind to seal the subs. Also make sure there enough air space behind to suit the subs.
Post by: s12vea on October 17, 2013, 22:19
That's what I'm thinking of doing.
Post by: Anonymous on October 21, 2013, 13:52
Hey...
Ive just seen this - im making a custom box for my 10"
I started it in May... still a work in progress ^.^
But its in the car ! and im just glueing the last few bits now
Post by: s12vea on October 21, 2013, 15:22
Get some pictures up mate. Be good to see
Post by: Anonymous on October 21, 2013, 17:05
I will do, cant right now - poor light and im frustrated with the damn thing...  but there is enough air for the sub to work which is great - ive got an alpine type r sub 1000w rms  s:D :D s:D  boooom!
put it this way... I wouldnt make a custom box again - it has been far to much work! there are SO many angles you need to take in. Do yourself a massive massive favour and get a under dash sub. SERIOUSLY.
Post by: Anonymous on October 21, 2013, 17:29
Just to expand on the above... sorry mods for double post.
In order to get the right size box you need to take the rear bin trays out and fill the gap with your box.
The front panel is at a slant - if you look at your bin doors now they slant - so you have to angle your cuts so then it fits and creates a seal - we measured 20 times and there are still some very worrying gaps.
The floor and back are the easy bits... but you have to make a slanted bit of wood that goes from the bottom up towards the middle of the car - and then a flat vertical piece to reach the roof.
The roof looks like steps it goes out then up then out then up and out again.... to get round all the nobbly bits and softop tray.
Dont even get me started on the side where the drivers side seatbelt is... In order to have enough air you need to maximise all the space in the rear bin - therefore you need a LOT of angles in order to make a seal.
Plus you will need to soundproof the floor of your rear bins - i used underlay. the back has carpet already and the front also needed underlay.
Sealing the box is the hardest - remember its not a square! there are a lot of angles and different bits of wood joined together you have to use enough glue to seal the box AND make it strong enough to hold the sub. For a good enough glue it takes 24 hours to set - so every time you put in the next bit... you normally have to wait a week before its actually sealed due to glueing every day.
The underdash sub i could have installed within 2 hours. I know its not gonna kick as much as a 10" but it does sound very good. The only real way the 10" will compete with the under dash sub is if you have a hard top (which i do).
Never the less i will take some pictures now....
Post by: Anonymous on October 21, 2013, 17:46
Pictures:
(http://i44.tinypic.com/2druwxk.jpg)
(http://i40.tinypic.com/nbdj44.jpg)
(http://i40.tinypic.com/wi4x87.jpg)
(http://i43.tinypic.com/o7kork.jpg)
(http://i42.tinypic.com/21edf7k.jpg)
(http://i44.tinypic.com/2qxcgf6.jpg)
(http://i39.tinypic.com/25rkv12.jpg)
(http://i43.tinypic.com/331d6xz.jpg)
(http://i42.tinypic.com/2v1nreu.jpg)
(http://i39.tinypic.com/2evdhea.jpg)
(http://i39.tinypic.com/23sjd00.jpg)
(http://i44.tinypic.com/2lbbymt.jpg)
Post by: s12vea on October 21, 2013, 18:02
Some good work going on there mate. Be worth it when it's done  s:) :) s:)
Post by: StuC on October 21, 2013, 19:57
Rich, have you jus maximised the air space by doing this build or have you calculated it?
I know a 12" needs 2 cubic feet. Looks like you have more than that there.
Post by: Anonymous on October 21, 2013, 20:14
Lol! Yeah ive calculated it. I cant remember the exact result but I know it was the perfect size
Post by: no1trancefan on November 14, 2013, 16:20
Quote from: "Flipside"What about one of these
the single is very good for its size
