Does anyone know somoe +ve points in the cabin area that i can use for some more leds?
I'm half way through knocking up some footwell LEDs that I'm going to splice into the cigarette lighter feeds.
Think ill use the same.
I had cathodes in before as were brighter but the other week having the music very loud i managed to give myself titanus and shatter one of the cathode inner tubes so swapping them all for led strips now
Just corrected my post, I've got LED strips as well. I had considered some cold cathodes too but think LEDs are probably the way to go nowadays anyway. s:) :) s:)
My plan is to hook them up to a rocker switch on a custom kick panel. I'd considered taking a feed each side off the door switches to make them come on with the interior light but I like the idea of being able to just have them on with the ignition if I choose.
Is the pink or white +ve on the cigarette socket wiring?
Thanks in advance
pink
I have mine wired into the sere power out for the aerial. Plus a rocker switch in case I want them off.
Quote from: "no1trancefan"Think ill use the same.
Stu did you miss this one? Which position is titanus? I've tried most positions but don't know this one. s:D :D s:D
It's amazing what youngsters get up to these days.
Mind you tinnitus is not nice hope it clears.
I noticed the spelling error as soon as posted but thought ah sod it no one will notice s:) :) s:)
