The Workshop => Audio / Security / Electrical => Topic started by: vx220 on July 18, 2015, 08:28
Title: under-dash sub-box plans?
Post by: vx220 on July 18, 2015, 08:28
Hi, been thinking about an under-dash woofer, as the boxes are NLA, does anyone have plans or even just the rough HxWxD?
Just thinking of a cheapy 6.5" woofer, driven from my headunit (it bridges to drive a sub)
I know this won't sound like the JL and an amp, but I reckon it'll cost me <£20 to build and fit, got to be worth it for a touch more bass? I can take a little of the strain off the standard door speakers using the headunit crossover as well...
I can easily make the box, used to make subwoofer cabinets and kick panels. If money was a bit mor available I would dive straight in for a proper system!
Title: Re: under-dash sub-box plans?
Post by: vx220 on July 18, 2015, 09:16
Also, do the existing UD boxes fire into the bulkhead or up or down? Or sideways!?
Thanks in advance!!!
Post by: stargazer30 on July 18, 2015, 11:08
They fire upwards to make max use of the corner effect for bass.  They work very well.
Post by: StuC on July 18, 2015, 11:09
They fire upwards, into the dash cavity.
Post by: vx220 on July 18, 2015, 14:39
Cheers for replies, thank you
Any ideas on a rough size so I can work out the volume?
I will be under there having a go in a week or so but a rough idea of box size would help me locate a woofer
Post by: stargazer30 on July 18, 2015, 20:01
Quote from: "vx220"Cheers for replies, thank you
Do a search for the fitting guide me and Nathan did and you will get a good idea, plenty of pics.   Its a complex shape to make and get the hardware in the correct locations so you'd be better off buying one off the forum.  I'm sure there's one for sale on here.
Volume wise its pretty small, but its sealed and the sub is only a 6" so it doesn't need much.
Post by: markiii on July 21, 2015, 22:35
I have the precut panels to make more of these if there is still a market
Post by: lamcote on July 22, 2015, 11:25
Would you sell the panels as a flat pack for DIY build?
Post by: Leethesparky on July 23, 2015, 12:16
I've got a under seat thingy squashed behind my passenger seat. Built in amp
sounds good, doesn't block the storage boxes and the seat goes almost all the way back.
(http://i376.photobucket.com/albums/oo203/Leethesparky/20150308_160602_zpslcprzuy5.jpg) (http://s376.photobucket.com/user/Leethesparky/media/20150308_160602_zpslcprzuy5.jpg.html)
Post by: markiii on July 23, 2015, 20:21
Quote from: "lamcote"Would you sell the panels as a flat pack for DIY build?
Not sure, hypothetically
Bearing in mind they would need assembly, sanding, filling, trimming e.t.c would there be demand?
Would you want the mounting brackets?
Post by: lamcote on July 23, 2015, 23:25
I guess it depends on the price difference between ready built and flat pack?
Post by: Mr X on July 26, 2015, 09:50
Quote from: "markiii"I have the precut panels to make more of these if there is still a market
I'd be very interested too! Either flat pack or pre-built. I guess flat pack would be easier to send out.
Post by: Bugster_MR2 on July 26, 2015, 12:06
Quote from: "Mr X"
+1
Post by: vx220 on July 26, 2015, 16:09
Just a thought,  does anyone think you'd get a 6x9 up there? I still haven't had a chance to get under there to grub around...
Post by: markiii on July 26, 2015, 21:27
6x9  wouldn't be a sub so why bother
Post by: vx220 on July 26, 2015, 21:32
Quote from: "markiii"6x9  wouldn't be a sub so why bother
Just on a tiny budget, can probably pinch a 6x9 or 6.5" just to add some reinforcement
Also, you can buy 6x9 subs, Genesis, JL and Kicker iirc? Adds a bit of surface area (if it would fit...)
Post by: vx220 on August 8, 2015, 08:51
Apart from the Inphase active sub, has there been any other active subs mounted under the dash?
Post by: adamjob on August 8, 2015, 10:00
I made a baffle board and fitted a 10" kicker free air sub, sounded pretty good but I had to use a lot of sound deadening to seal the dash a bit and stop unwanted vibrations.
Post by: vx220 on August 8, 2015, 10:16
So busy with work I haven't been able to get up there. As work has been busy (but could disappear any minute...) I am torn between my initial no-money-stick-a-cheapie-woofer under there driven by the head unit (it has sub bridging output) or if work continues to find me, splash out on something active to go up there? But while work is coming in, I don't really get time to even have a rummage with the tape measure!
Post by: jeffsimply on September 30, 2015, 09:58
I would 100% buy one off you if you made another batch.
