The Workshop => Performance Related => Topic started by: weeJohn on December 7, 2015, 11:05
Title: DIY your 2ZZ swap engine mount bridge.
Post by: weeJohn on December 7, 2015, 11:05
This may not go down well with everyone, my intention is not to rub anyones nose in it and I apologise beforehand to anyone who might feel this way. This bridge mount is available to buy from several reputable sources, their prices are good, as is their quality. But I know how I felt myself, having the resources and capability to make this yourself makes buying this a bit hard. So for anyone who would like to have a go at making your own, I made mine to these dimensions out of 12mm steel plate and it worked perfectly.
(http://i41.photobucket.com/albums/e278/weeJohn/5b73cd03-86b2-4b91-ae35-7459387f3735.jpg)
Obviously, the positions of the holes are the most crucial thing, take your time and draw this out on a piece of paper, then transfer that paper template to your steel. take all your reference dimensions from the 10mm hole on the left and the straight bottom edge and you will be spot on. If you wish to drill all the holes 1mm bigger to add a little clearance to make fitting easier, this will not affect its working ability either.
Title: Re: DIY your 2ZZ swap engine mount bridge.
Post by: Craig on December 7, 2015, 17:28
Thanks, like you I feel like its crazy buying one of these when I have a fabrication shop at my disposal!
Post by: frootloops on December 7, 2015, 18:25
Good work and definitely the best option for those capable of making one. There's also a template that you print off to size that's knocking about the forum which some might find easier.
Post by: weeJohn on December 7, 2015, 19:25
Quote from: "frootloops"Good work and definitely the best option for those capable of making one. There's also a template that you print off to size that's knocking about the forum which some might find easier.
I was sent a copy of the template which I printed out and checked against my engine mount. It must be a case of the image getting resized each time its saved and printed, but the holes did not line up until I resized the image before printing.
Post by: feralcrew on December 8, 2015, 10:05
Thank you very much! Maybe someone has a link to the template? Please PM me if you can!
Post by: jaworjawor on December 26, 2015, 21:02
I have this in cad, I did myself the bridge mount with my swap, there are pictures somewhere on this forum
Post by: vasek.x1 on October 15, 2017, 16:54
Hi, I know, that this post is quite old, but does anybody has a drawing of the bracket with correct final dimensions (for 2zz from Celica)? The one posted here is nicely drawn, but with incorrect dimensional constraints (ie. how can a dimension of 54mm be smaller than 52mm?). The other I found here  m https://drive.google.com/file/d/0B56j8y ... 9ERkE/view (https://drive.google.com/file/d/0B56j8yOiRKX3Q0Y5azJFWV9ERkE/view) m  is better, but a bit out of scale, though (the distances like 34.83mm or 98.09mm are not much convincing and I don't know how to round them up the best)...
Post by: alancsalt on October 16, 2017, 23:44
The mount I bought compared with a template I found.
[attachment=0:1dl3md61] ia0 mount.jpg ia0 [/attachment:1dl3md61]
Think "manufacturing tolerances". It's not like this is as much a precision part as a piston or crankshaft journal...
Also ..  l viewtopic.php?t=9211&start=630 (http://www.mr2roc.org/phpBB3/viewtopic.php?t=9211&start=630) l
Post by: ale_rx on May 17, 2023, 08:29
hi folks, this is a longshot but worth trying..
is there anywhere on the forum a dwg or a file with the measures for the motor mount?
i'd like to build it myself since where i work i have access to a lasercut machine..
