The Workshop => Audio / Security / Electrical => Topic started by: Barney Bear on February 5, 2016, 09:01
Title: Heater Bulbs
Post by: Barney Bear on February 5, 2016, 09:01
Just incase anyone needs to order the 2 bulbs behind the heater controls
little green plastic with bulb securely fitted
part no    T 900 10-05124  £5.90 each plus VAT from Mr Ts  s:D :D s:D
Title: Re: Heater Bulbs
Post by: Jock on March 26, 2016, 17:40
Got a wee surprise when checking my heater bulbs   s:scared: :scared: s:scared:
(http://i1341.photobucket.com/albums/o750/ironside6/DSC01228_zpsfoowmlqi.jpg) (http://s1341.photobucket.com/user/ironside6/media/DSC01228_zpsfoowmlqi.jpg.html)
Having sorted my main dials I recognised the LED wedges but not the ribbon beasties and the behind the scenes "connections":
(http://i1341.photobucket.com/albums/o750/ironside6/DSC01229_zps8robfhkr.jpg) (http://s1341.photobucket.com/user/ironside6/media/DSC01229_zps8robfhkr.jpg.html)
So a tad of weight loss:
(http://i1341.photobucket.com/albums/o750/ironside6/DSC01230_zpsbpqbhrlt.jpg) (http://s1341.photobucket.com/user/ironside6/media/DSC01230_zpsbpqbhrlt.jpg.html)
The two green holders are the bulb holders with the bulbs replaced by red LED wedges.
MrT on Monday with Barney Bear part number   s:bounce: :bounce: s:bounce:
Post by: Barney Bear on March 26, 2016, 17:47
Pm me your address have some led ones that should fit
Post by: Jock on March 26, 2016, 18:34
Pm sent. Thanks   s:bounce: :bounce: s:bounce:
Post by: StuC on March 26, 2016, 18:35
are the bulbs in the heater panel the same as the cluster?
Post by: Jock on March 26, 2016, 18:45
Nope.
The heater panel has two (Barney correct MrT wrong) which are larger in diameter.  The Toshiba v-2 holder is used in the cluster which takes a 5mm 1.2w   s:) :) s:)
Post by: Barney Bear on March 26, 2016, 19:28
Will send first thing Tues for you
Would put them in the post tonight but doubt they would get to you any sooner   s:D :D s:D
Post by: StuC on March 26, 2016, 19:52
Quote from: "Jock"Nope.
Are these the badgers?
LINKY (http://pages.ebay.com/motors/link/?nav=item.view&id=251847754241&alt=web)
Post by: Barney Bear on March 26, 2016, 20:05
No Mr T ones are a green base with the bulb hard wired into it   s:D :D s:D
T4.7
Or these  m http://www.ebay.co.uk/itm/272104384303? ... EBIDX%3AIT (http://www.ebay.co.uk/itm/272104384303?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT) m
I ordered the led ones but got fed up waiting for them to arrive and ended up fitting plasma dials instead
If you need two Stu pm me as I have another pair spare   s:D :D s:D
Post by: StuC on March 26, 2016, 21:40
You have extra extra spares?
That is some planning.
Thank you.  s:-D :-D s:-D
Post by: Jock on March 26, 2016, 22:17
Stu your badgers are too wee   s:scared: :scared: s:scared:
The Toshiba v-2 is the holder which takes a 5mm bulb or wedge.  The two for the heater, which Barney is referring to take a wider diameter bulb or wedge.  So Barney has bigger nadgers   s:crazyeyes: :crazyeyes: s:crazyeyes:
I am not sure if the OD of the holder differs because my clock's gone back, its wet and I'm scared of the dark - no bulbs   s:lol: :lol: s:lol:
Post by: Nunfa1 on March 27, 2016, 09:24
A note about the LEDs. I've fitted LED T4.7 in mine, the wire connection is a too thin so you need to bend up the wire that goes underneath and fold it back against the wire on top. This gives a better connection to the pcb.
The other thing to note, LEDs do not give off much light to the sides so the spread across the heater dials is not even. It's not a massive deal but it's also not perfect. That may be why there was some extra's behind your panel Jock.
Post by: Barney Bear on March 27, 2016, 09:25
Bulbs on the speedo cluster are set in a little black plastic base and they are indeed wedge bulbs that pull out
Also aces stability on these is from the back of the cluster so no need to touch the front of the dials
Have some of to the wedge bulbs somewhere if needed
  s:D :D s:D
Stu pm your details and will put in the post for you
Post by: Jock on March 27, 2016, 11:11
Correct Nunfa a misuse of LED's combined with bodged wiring.  For anyone thinking of doing this just look at the strips, all damaged melted and brittle.  Also loose wiring at back of PCB could have shorted the lot   s:flame: :flame: s:flame:
Post by: Barney Bear on March 27, 2016, 12:27
Led s In the post guys
They are the extra bright 3 light ones not single so may work better
I did have blue single led before the plasma and they worked fine but as said bit Tim but dim   s:bounce: :bounce: s:bounce:
  s:D :D s:D
Post by: StuC on March 27, 2016, 13:47
Legend BB. Many thanks.  :-) :-) :-)
Post by: Jock on March 27, 2016, 15:17
Thanks Barney   s:bounce: :bounce: s:bounce:
Post by: Standard on March 31, 2016, 22:02
I was just going to create a thread about my poorly lit heater controls...
(http://i44.photobucket.com/albums/f46/andy6-8/832C6C2B-865F-47CC-B368-69B85EDA7F12.jpg) (http://s44.photobucket.com/user/andy6-8/media/832C6C2B-865F-47CC-B368-69B85EDA7F12.jpg.html)
What is the fix for this? Or am I in the wrong thread?
Post by: Jock on March 31, 2016, 22:23
Hi Standard looks like the driver's side bulb has failed.  See first pic of mine above the bulbs were replaced with LED wedges.
Pull off the 3 dials and the knob on the air-vent slider.
Remove the two screws and you can pull out the facia and see the bulbs or possibly some mod (LED?).
To get at the bulb holders its 3 small screws and pull forward the PCB.  Watch out for the "passenger" plate or it will disappear somewhere   s:( :( s:(
Post by: StuC on March 31, 2016, 23:05
Quote from: "Barney Bear"Led s In the post guys
  s:D :D s:D
Bulbs arrived today. Many many thanks.   s:bowdown: :bowdown: s:bowdown:    s:bowdown: :bowdown: s:bowdown:
Post by: Standard on April 1, 2016, 07:28
Quote from: "Jock"Hi Standard looks like the driver's side bulb has failed.  See first pic of mine above the bulbs were replaced with LED wedges.
Do the bulbs not last very long then?
I'd like the dials to match the other controls. Is there much difference with the colour?
Post by: Jock on April 1, 2016, 07:51
Depends what you mean by "long".  I am not aware of an issue.  Think in my case a previous owner fancied LED's and red ones in the heater and botched the job.
As for colour if all MrT bulbs then colours come from dials and bulbs match.  I have yet to fit the lights courtesy of Barney which are different so may give a different kind of white   s:? :? s:?
This is a weekend job so will post results   s:) :) s:)
Post by: Barney Bear on April 1, 2016, 08:18
Mine lasted for 11 years before one blew
Standard if you would like the last pair of LED ones pm me your details   s:D :D s:D
or you could go for plasma(http://i564.photobucket.com/albums/ss83/midship54/S1870001_zps3g0aymvf.jpg) (http://s564.photobucket.com/user/midship54/media/S1870001_zps3g0aymvf.jpg.html)
Post by: Barney Bear on April 1, 2016, 10:45
Hello Standard
got your PM and bulbs are in the post for you   s:D :D s:D
Post by: Standard on April 2, 2016, 09:30
Excellent. Thank you.
Post by: Jock on April 2, 2016, 18:56
Bad news on the LEDs - they don't fit   s:bowdown: :bowdown: s:bowdown:  .
The base of the bulb is not aligned with the top of the holder and it will not fit the hole   s:( :( s:(  .
Have replaced with MrT and all main dial bulbs and now lit up like a gin palace   s:bounce: :bounce: s:bounce:    s:bounce: :bounce: s:bounce:    s:bounce: :bounce: s:bounce:
Post by: Barney Bear on April 2, 2016, 18:59
 s:oops: :oops: s:oops:  sorry mate
Glad you got it sorted though
Post by: StuC on April 2, 2016, 21:39
Managed to change mine tonight too. The holders weren't as easy to fit as the stock holders, based on them having a lower profile.
Got there in the end though.  :-) :-) :-)
Post by: Jock on April 3, 2016, 00:06
Not a problem Barney   s:) :) s:)  unless your making these on the sly   s:bowdown: :bowdown: s:bowdown:
Be good to get a pic from StuC to see the effect and I'll try to compare.
Standard will be on edge now   s:wink: :wink: s:wink:
Post by: StuC on April 3, 2016, 10:17
I had in mind to take before and after pics as I thought it would be a simple fix. I'll try and get an 'after' shot tonight at a similar time for comparison.... If i remember.
Post by: Standard on April 3, 2016, 10:51
Quote from: "Jock"Not a problem Barney   s:) :) s:)  unless your making these on the sly   s:bowdown: :bowdown: s:bowdown:
So these are the wrong ones? Damn. Can't believe how quickly they came in the post either (thanks again). I'm just glad I found out now before I had the dash in pieces.
I will be keeping an eye out for an update!  s:? :? s:?
Post by: Barney Bear on April 3, 2016, 12:13
they fitted mine sorry guys but then again could be an odd one as MrT insisted i would only need one bulb not two  s:) :) s:)
Post by: Jock on April 3, 2016, 21:04
Ok dark out there   s:scared: :scared: s:scared:
This is a pic of the different holders with MrT on the right as you look:
(http://i1341.photobucket.com/albums/o750/ironside6/DSC01237_zpsxndibax2.jpg) (http://s1341.photobucket.com/user/ironside6/media/DSC01237_zpsxndibax2.jpg.html)
You will see the issue with the bulb base and holder alignment.
Pics taken in dark and no flash sitting back in the seat with standard bulbs fitted:
(http://i1341.photobucket.com/albums/o750/ironside6/DSC01240_zpslrxksgvq.jpg) (http://s1341.photobucket.com/user/ironside6/media/DSC01240_zpslrxksgvq.jpg.html)
(http://i1341.photobucket.com/albums/o750/ironside6/DSC01241_zpsjhegp381.jpg) (http://s1341.photobucket.com/user/ironside6/media/DSC01241_zpsjhegp381.jpg.html)
I like the "standard"   s:bounce: :bounce: s:bounce:    s:bounce: :bounce: s:bounce:    s:bounce: :bounce: s:bounce:
Post by: Barney Bear on April 4, 2016, 07:13
Mine are different then as they are green not black the MrT ones that is
Post by: Jock on April 4, 2016, 08:40
I'm not black either   s:wink: :wink: s:wink:   .  I suppose all look alike in the dark   s:scared: :scared: s:scared:
This with flash:
(http://i1341.photobucket.com/albums/o750/ironside6/DSC01238_zpsris5x7wf.jpg) (http://s1341.photobucket.com/user/ironside6/media/DSC01238_zpsris5x7wf.jpg.html)
Post by: skidmark on May 3, 2016, 22:13
One of mine is out, need to pop to Mr T to get one.
Also, the bulb in the heated rear window switch doesn't work, does anyone know if that can be replaced ?
I did try and pry it apart but felt like I was going to break something.
Mark
