The Workshop => Performance Related => Topic started by: jvanzyl on August 5, 2016, 10:41
Title: Sensible approach to spending money on 2001 with 123K
Post by: jvanzyl on August 5, 2016, 10:41
Hi Folks,
Would appreciate your thoughts here. I THINK that I want to put coilovers on my car to improve the ride - I'm currently opting for the MeisterR ones.
In addition, I want to complete the polybushing of the rear bushes as I suspect they are perished.
However I do appreciate that my car is old and has done a lot of miles - does anyone think this is a foolish avenue to take?
All in it's probably another £1K to do the above...
EDIT: Forgot to mention that this is my daily driver! I do about 7k a year.
Appreciate your input!
Cheers,
John
Title: Re: Sensible approach to spending money on 2001 with 123K
Post by: Jrichards20 on August 5, 2016, 10:59
I've just spend an fair whack on a 2000 with 160k miles. So as long as the chassis is fine, you can just keep changing the old bits and you'll end up with a new car. Well that was my logic anyway  s:) :) s:)
Post by: secla on August 5, 2016, 11:10
If you like the car and plan to keep it then spend as much as you like, just realise you won't see the money back
Post by: jvanzyl on August 5, 2016, 11:17
I DO like the car  :-) :-) :-)
I'm under the understanding that the chassis fine - I guess it really does matter how deep your pockets are!
Post by: Topdownman on August 5, 2016, 11:26
I think that if you plan to keep the car for at least a few years you will be fine. You will not be suffering much depreciation on your 2 compared to a "normal" car so that will off set what you spend on the 2.
I think the suspension needs to be changed on any mileage if it is 15 years old and you want to get it handling as it should.
Post by: jvanzyl on August 5, 2016, 13:20
Thanks for the wisdom  :-) :-) :-)
I certainly hope to keep it for a few more years! I think I'm "okish" with the cornering - but I suspect that I'm used to something that's not operating the way it should.
Additionally I'd love for it to handle the bumps and rubbishy roads better.
Post by: Mikeymead on August 5, 2016, 14:21
Having MeisterR's on mine now for a few months I wouldn't say they improve the ride, even on quite soft settings the ride is definitely harder than stock which I feel makes the car a bit more skittish in a bumpy corner, there is definitely less body roll and I think the point at which it lets go is probably higher but it gives you less warning. From what I gather it looks like Simon is going from MeisterR coilovers to KYB which is basically stock. At slow speed the ride on mine is quite annoying though it does handle speed bumps quite nicely. At high speed I do think the dampers have better control than stock and the ride then is quite good. Mine only had about 65000 miles on them when I changed.
PS If you want to try mine on MeisterR's then you can at Dong Day, I hope to get there for the after noon.
Post by: jvanzyl on August 5, 2016, 14:46
errr..... ok. I completely thought that the MeisterR's were the best of the bunch (bc/yellowspeed) when it came to improving the ride!... doh..
I think I will take you up on your offer at Dong day! I basically want to make my daily commute more comfortable and not lose the ability to enjoy the occasional roundabout! (track days are becoming a distant hope I think!).
Does anyone else have any views on what suspension setup makes for the best daily commute and occasional blast?
Post by: Jrichards20 on August 5, 2016, 14:50
MeisterRs CRD+ are not soft. If you bring them down too low, I felt they got really "boaty" if that makes any sense, wasn't a very good feeling. They need to be around the middle setting for a decent ride, but its going to be a lot harsher than stock.
Post by: secla on August 5, 2016, 15:05
If your looking for better comfort no coilover is going to do that very well
Post by: jvanzyl on August 5, 2016, 15:38
crud... sooooo basically what you're saying then is that I'll be trying to source replacement stock/kyb struts and then trying to figure out the right springs and then see if I need new top mounts or not debacle.. damn. I had hoped to avoid that by just biting the bullet and going straight for coilovers!
Anyone have any opinions on "sachs"? Eurocarparts is always emailing me with some kind of discount code and they are the ones that they sell..
Post by: MR TWO on August 5, 2016, 15:51
My braces and BC's improved the handling immeasurably, whilst making the actual ride harsher than I wanted. Backing off the coilovers settings only made the car bouncy and was worse.
Stiffening the suspension requires an equal amount of softening somewhere else to compensate - if you want a normal ride comfortwise.
Consider tyres with softer side walls, standard size wheels without low profile tyres.
How good us the padding in your fifteen year old seat?
I resolved my problems with Toyo's and fully sprung well padded Porsche seats.
Post by: jvanzyl on August 5, 2016, 16:00
hmmm.... ok I've got the Toyo's at least!
Dare I ask what you paid for the Porsche seats??
Post by: MR TWO on August 5, 2016, 16:16
Quote from: "jvanzyl"hmmm.... ok I've got the Toyo's at least!
I bought them on eBay with the door cards, rear seat/pads, speakers etc for  £220. They are 911 Carrera Turbo with pinhole leather in black. Heated and electric which is an unescessary but nice bonus. I must get around to selling the other parts...
I don't think they were expensive, since they resolved the harsh ride and look great.
Post by: jvanzyl on August 5, 2016, 17:15
wow - totally hadn't considered changing the seat. I'm assuming that you buy the seat with the seat rail - but is there anything you have to do to get the porsche seat rail to work with the toyota floor? Do you need any kind of adapter?
Post by: MR TWO on August 5, 2016, 18:11
Quote from: "jvanzyl"wow - totally hadn't considered changing the seat. I'm assuming that you buy the seat with the seat rail - but is there anything you have to do to get the porsche seat rail to work with the toyota floor? Do you need any kind of adapter?
You need to have a bracket conversion.  I bought some from an unmentionable guy we all know who lives in the Lake District.  Basically you need a square frame made of steel, mine are made from approx 50mm x 7mm. This frame has to be large enough to fit over the bolt holes in the floor. The tricky part is to make the spur which attaches to the centre hump for the rear inside bolt. Make an identical frame from cardboard and work out the approx location of the floor holes. Mark them on the metal frame. Drill the first hole and bolt down the metal tight using the seat bolt. Then you drill the remaining three holes.  one at a time, bolting the frame in place -  its best to use a small drill and work up to be sure the holes are correct.
Finally you get the seat runners welded to the frame. Painted with hammerite makes them look finished/ factory . Then bolt in the car.
Its a bit of work, but it makes the handling mods really enjoyable, and you could always get someone to do this for you like I did!
Post by: cptspaulding on August 5, 2016, 18:21
For daily driving I would (and I already have done) stay stock. KYB shocks with stock springs. Get the geometry done after.
Each to their own but Toyota spent a lot of money developing this car to handle beautifully on a stock set up.
Sent from my LG-H815 using Tapatalk
Post by: Ardent on August 5, 2016, 19:22
What the Captain said.
If comfort is to be considered. going coilys AND polybushing as you imply, is not the route to comfort.
Ride is a very subject thing. What is acceptable to one is a bone shaker to someone else.
As the Captain. Kybs new springs and importantly a good quality Geo after.
And fresh rubber if not already done so.
I had all the bits nbobs, but not until I had the Geo done, did it come together as a complete package.
Now.   s:mrgreen: :mrgreen: s:mrgreen:    s:bounce: :bounce: s:bounce:    s:bowdown: :bowdown: s:bowdown:
Post by: lamcote on August 5, 2016, 21:12
Have you considered Koni adjustable damper inserts for the standard struts? You can then retain the standard springs. I guess this could be the ultimate option for good handling while retaining a softer ride.
Post by: John is200sport on August 5, 2016, 22:36
I think suspension and bushes would be fairly cost effective and sensible given age and mileage. A good set of matching tyres. To save money you could look at your own maintenance and servicing.
Good quality second hand bracing maybe an idea, keep the old ones and should you sell the car it's easy to swap back and sell on. Some sort of mid underbracing on your car seems to be recommended but getting hard/expensive to find.
Good luck with the project.
Post by: 1979scotte on August 6, 2016, 10:42
You need to get a ride in a few cars.
Ask jason ARDENT for a go in his. Almost new stock suspension.
Take Mike up on his offer. New meister r.
Dont poly bush a daily driver imho.
Please remember that at your milage your stock suspension is shot and a move to KYB dampers and Tein springs will only improve matters.
I could be wrong but somone told me most manufacturers recommend replacement of dampers at 50k.
Post by: Ardent on August 6, 2016, 10:59
Just to repeat all of the above.
These are old cars.
A fresh stock set up will improve things no end.
Post by: jvanzyl on August 6, 2016, 11:19
Thanks guys!
I'm kinda committed to finishing the Poly's at the moment as the fronts were done last summer so I may as well finish it and THEN do the dampers and springs.
The Koni adjustable things sound good - any one know where to buy this stuff?
I shall make sure i bathe before dong day and sit in all your cars!  s;-) ;-) s;-)
Post by: 1979scotte on August 6, 2016, 12:24
 m http://www.dcperformance.co.uk/cheap/25 ... -3991.html (http://www.dcperformance.co.uk/cheap/250907/toyota/koni-sport-suspension-kits/1140-3991.html) m
Koni with HR springs.
Loads on ebay too.
Post by: jvanzyl on August 8, 2016, 10:07
Awesome - ok so I'm feeling good about the Koni Sports - now all I need to do is source topmounts all round?
A lot of places seem to advertise the front top mounts (seem some good oem type ones on ebay from the US) - anyone know where you get the rears from? Are they called something other than a "rear top mount"?
Post by: Topdownman on August 8, 2016, 12:26
It is the front top mounts that go as they have a bearing etc in them that allows the mount to rotate. The rears are fixed so dont need replacing.
You wont know if you need new fronts until you take the shocks off and you can have a good look at them.
(http://i991.photobucket.com/albums/af36/skt_photos/20160808_121226.jpg) (http://s991.photobucket.com/user/skt_photos/media/20160808_121226.jpg.html)
You may well need new front and rear boots (which come with the bumpstops) at £53.90 for all 4 from mr2-ben.
You take a chance if you go for the konis as they may still be too harsh, especially with the polybushes. Also, kybs and teins would only be about £390 so £170 cheaper than the koni combo....
Post by: jvanzyl on August 8, 2016, 14:05
ah! .. OK so the shopping list as it now stands:
2X Front Top mounts - £118
4X dust with bump stops £50
Koni Sport Dampers with HR springs - £566
Grand Total approx £734 PLUS LABOUR & re-alignment etc..
Point taken about the Koni's being too harsh... is there a nice little graph (something like Josh did for the Engine swaps/costs and power thing) that shows all the different suspension setups for harshness to comfort etc?
Am I right in assuming that the list with "1 = most comfortable" highest number =" most harsh" is as follows:
1. Toyota Replacements
2. KYBS
3. Koni Sports
4. Yellowspeeds
5. BC's
6. MeisterR's
It does kind of look like the whole suspension refresh is much of a muchness in terms of cost - the determining factor does seem to be the desire for adjustment and particular ride.
Post by: Topdownman on August 8, 2016, 14:52
This is the only ref document I remember seeing but this is about spring rates rather than damping.
 l viewtopic.php?f=46&t=5018 (http://www.mr2roc.org/phpBB3/viewtopic.php?f=46&t=5018) l
Like the idea of trying to rate them but hard to do and very subjective I reckon!
Heres my thoughts;
 Toyota Replacements or KYBS- same rate. (Choice of either lowering springs or stock springs). Some people reckon the tein springs are their favourite mod.
 Koni Sports- the advert says plus 25% minimum higher damping than stock (I have not heard anyone mention them on here, not sure what that means?). You may still need top mounts and boots with these whereas all the coilovers do not need these so the konis are potentially pretty expensive.
 Yellowspeeds BC's MeisterR's -people on here like all of them but you can get the BCs with a choice of 4/6 kg rates or 5/7 which gives more options (rather than having to buy additional springs and changing them over).
Best to try and sit in a few cars at dong day I think before you decide?
Post by: 1979scotte on August 8, 2016, 15:41
meister ride better than BC whichever spring rate you choose.
Its not all about spring rates but how it interacts with the dampers.
Not enough info on yellow speed we have only had a couple of people fit them.
I know koni yellows have been suggested but again only a few people have fitted them.
For me personally as you have already polybushed and taken a lot of slack out i would go for KYB and Tein springs.
Again i never regretted getting my meister R. What you loose in comfort you gain in handling and feel unless the surface is truly awful or you have them set to hard.
Make no decisions until you have tried a few different options.
Post by: MR TWO on August 8, 2016, 15:50
Quote from: "1979scotte"meister ride better than BC whichever spring rate you choose.
I have never been in a car fitted with Meister coilovers, so I am in the dark as to what they do to create this superior "ride".  Care to illuminate me?
Post by: 1979scotte on August 9, 2016, 11:02
Quote from: "MR TWO"
Ask shanazzle. He has been in mine and has bc on his.
I think andy ayres has tried the lot too. So ask him.
BC 5/7 are considered too hard for the road. Meisterr 5/7 arent.
Most people go for 4/6.
BC are possibly better on track.
I like my setup and only find the ride uncomfortable over poor surfaces huge potholes etc.
Post by: shnazzle on August 9, 2016, 17:21
Confirmed; MeisterR on 5/7 was more comfortable on the road than my BCs with 4/6. But it was a very limited drive in Scotte's
BCs have the reputation to be slightly better on track, but this is unconfirmed really. Probably quite unnoticeable.
I wouldn't exchange my BCs for MeisterRs though. The cost wouldn't be worth the difference in ride.
Post by: Essex2Visuvesi on August 9, 2016, 19:38
Me either!
I have a set of RX8 seats in the shed... must investigate
Also what are peoples opinions on the yellowspeed for road use?
Post by: MR TWO on August 9, 2016, 19:40
Shnazzle &  Scott.
That's really interesting....  Do you both have the same tyres?
Post by: MR TWO on August 9, 2016, 19:49
Quote from: "Essex2Visuvesi"
Me either!
A well sprung seat compensates the increased stiffness. I figured turbo Carreras are super stiff yet never saw complaints about the ride.  So it was an obvious solution to my problem.
Post by: shnazzle on August 9, 2016, 19:53
Quote from: "MR TWO"Shnazzle &  Scott.
Yup. Both on the AD08Rs, same sizes as well I think.
Post by: 1979scotte on August 9, 2016, 20:07
Yes.
AD08R
Mine are probably slighty bigger but same size rims.
Post by: MR TWO on August 9, 2016, 20:20
I will have to get a ride in your cars - on a bumpy road - consecutively next time we all meet.
Shnazzle what settings are yours on?
Post by: shnazzle on August 9, 2016, 20:26
Quote from: "MR TWO"I will have to get a ride in your cars - on a bumpy road - consecutively next time we all meet.
BCs BH-RA (rear rubber top mounts), 4/6 springs, AD08Rs in 195/50/15 and 225/45/16, stock FL alloys, front and rear strut braces.
All else stock as far as handling goes
Post by: Blue al on August 9, 2016, 20:35
Not sure if this is a useful comparison at all,
but found in my mini upgrading from my BC springs to supposedly stiffer swift metric race springs improved ride and control all round
Could be a halfway house option for you ?
 m http://www.swiftsprings.net/products/un ... rings.html (http://www.swiftsprings.net/products/universal/metric-coilover-springs.html) m
FOR MR SHNAZZEL   s:mrgreen: :mrgreen: s:mrgreen:
Your Quote fell off my post   s:lol: :lol: s:lol:
Post by: 1979scotte on August 9, 2016, 20:37
Quote from: "shnazzle"
I have meister zeta r
Front and rear trd
Matt mid brace
Kirks inserts
205 front 225 rear tyres
Post by: shnazzle on August 9, 2016, 20:39
Ah, forgot about the mid brace, have that too.
Post by: jvanzyl on August 15, 2016, 09:31
Right!
So having had some great drives in cars with MeisterR's on the weekend - I'm actually happy with the concept of going with Coilovers (I've not had a go with oem refresh and Tein -S though).
I was doing some more googling and found that there are actually more variants to the Yellowspeeds! (to make matters harder! - literally I think.)
So the new order of things as far as I can tell is:
2. KYBS + TEIN-S
3. Koni Sports
4. Yellowspeeds
 a - (Pro Sport)  m http://www.tarmacsportz.co.uk/GB/DYNAMI ... S023_.aspx (http://www.tarmacsportz.co.uk/GB/DYNAMIC_PRO_SPORT_COILOVERS_TOYOTA_MR2_SPYDER_00-07/YS01-TY-DPS023_.aspx) m  ( I know GT4play has them cheaper)
 b.  (Pro Drift)  m http://www.tarmacsportz.co.uk/GB/DYNAMI ... D006_.aspx (http://www.tarmacsportz.co.uk/GB/DYNAMIC_PRO_DRIFT_COILOVERS_TOYOTA_MR2_SPYDER_00-07/YS01-TY-DPD006_.aspx) m
 c.  (Premium Competiition)  m http://www.tarmacsportz.co.uk/GB/PREMIU ... C016_.aspx (http://www.tarmacsportz.co.uk/GB/PREMIUM_COMPETITION_COILOVERS_TOYOTA_MR2_SPYDER_00-07/YS01-TY-PC016_.aspx) m
4. BC's
 a. R something
 b. R something - more expensive
 c. R something = Even more expensive
4. MeisterR's
4. TEIN/ KYBs etc for the mega rich..
Post by: shnazzle on August 15, 2016, 10:06
Sounds silly as I have BCs but...I'd opt for Meisters over BC. Although, I should give MEisters a proper go sometime on different settings to see where the weaknesses are.
Post by: jvanzyl on August 15, 2016, 11:14
Well my impression of them was that the MeisterR's were just so much better than my seriously jarring setup...
I'm going to have to do some research on the different options of yellow speed.... apart from height adjustment and dampening control..what are the "must haves" for coilovers?
Post by: shnazzle on August 15, 2016, 11:22
Quote from: "jvanzyl"Well my impression of them was that the MeisterR's were just so much better than my seriously jarring setup...
I meant that on your list, Meisters are lower on the list than BC, but I;d switch it around
Post by: jvanzyl on August 15, 2016, 14:01
ahh
corrected below then - anyone else have any input on the order of "comfort"?
2. KYBS + TEIN-S
3. Koni Sports
4. Yellowspeeds
4. MeisterR's
4. BC's
 a. R something
Post by: 1979scotte on August 15, 2016, 15:43
I hate to say this.
I hope that is just your high mileage shocks and springs that are making your ride so jarring and not those polybushes.
Post by: jvanzyl on August 15, 2016, 16:29
It's at the back of my mind!  s:-( :-( s:-(
Post by: shnazzle on August 15, 2016, 22:43
I hate to say this.
Oh... Polybushes....yeah...stick to stock  s:) :) s:)
Post by: jvanzyl on August 15, 2016, 23:10
Is this based on experience or hear say?  :-) :-) :-)
Post by: shnazzle on August 15, 2016, 23:53
A hell of a lot of people on various forums across various cars writing that it makes for a bumpy ride and lots of vibration in the cabin. Although the latter is more when polybushing engine  mounts
Post by: 1979scotte on August 16, 2016, 06:13
Thing is i have gone for kirks inserts for my engine mounts which is like half polybushing and i quite like it.
Different strokes for different folks.
Post by: shnazzle on August 16, 2016, 07:08
Was the same for people who put single mass flywheels in instead of dual mass. Rattles like hell but gives that sports car feel.
I'd want a dedicated "fun" car for things like that. Not in a daily.
