The Workshop => Performance Related => Topic started by: MilesH on March 21, 2017, 10:29
Title: Water temp gauge
Post by: MilesH on March 21, 2017, 10:29
Question for those who run a separate coolant temperature gauge.....where have you mounted your sender?
I found it fitted very nicely in place of the drain plug on the back of the engine, but after 10 minutes use it vibrated so much that it broke the sender! (poly engine mounts).
Are there any tried and tested options?
Title: Re: Water temp gauge
Post by: Alex Knight on March 22, 2017, 13:52
I've mostly seen spliced into coolant hoses.
Post by: MilesH on March 22, 2017, 21:16
Quote from: "Alex Knight"I've mostly seen spliced into coolant hoses.
I've gone for splicing the hose that runs from the thermostat and bought an alloy adapter to hold the sender  s:) :) s:)
Post by: andy bird on April 1, 2017, 22:59
Could it kit be fitted wherever the factory one us and just connected to the factory sender?
Post by: Dougster7 on April 21, 2017, 22:12
I tried that and didn't work
Post by: Dougster7 on June 30, 2017, 20:25
MilesH, do you have any pics of what you did here and is it still holding up?
