I have a P0141 code for the long lead sensor. Have followed the great advice on here and fitted a resistor, cleared he code and went for a run, no cel so great news. However how hot should the resistor be after a 10 minute run. It didn't burn my finger but wouldn't want to touch it for more than a second. The one I fitted was 50w 22R .
Many thanks
Malcolm
It should be hot, thats why you need one with a heatsink and mount it to a metal panel for extra heat dissipation. s:-D :-D s:-D
Glad to hear you sorted this common issue with this handy fix. s:-D :-D s:-D
22R is only dissipating around 6.5W at 12V so should be comfortably ok.
