The Workshop => Maintenance, Problems & Troubleshooting => Topic started by: Myles1ZZ on May 30, 2017, 09:26
Title: Fluid Leak!
Post by: Myles1ZZ on May 30, 2017, 09:26
Hi All!
Had the car in to Kwikfit on Friday to get a laser wheel alignment done and now the handling is spot on! However I now seem to have developed a leak from the front drivers side of the car... Trouble is that none of my fluid levels seem to have gone down? It seems to be roughly the area of the brake master cylinder but the master itself is bone dry to the touch and the brake fluid level is still at max???
I'm going to have a further investigation tonight after work. What should I be paying attention to? Why are my levels not going down?
Any ideas appreciated!!   s:) :) s:)
Title: Re: Fluid Leak!
Post by: Carolyn on May 30, 2017, 09:33
Windshield washer system??
Post by: Myles1ZZ on May 30, 2017, 10:42
No, it's not wiper fluid. It's pretty oily and smells a bit like WD40. I had it into the local garage on Thursday to have the track rod on the same side replaced so I'm wondering if they have broken something while they were working in that area.
Post by: Carolyn on May 30, 2017, 11:10
Under the plastic you also have clutch fluid, and power steering pipes.
Post by: cptspaulding on May 30, 2017, 11:26
My bet is the power steering pipes. They tend to corrode & leak at the point where they're clamped between the pump & the rack. Plastics off in the frunk & look down there with a torch you'll see if it's that.
Sent from my Moto G (4) using Tapatalk
Post by: Myles1ZZ on May 30, 2017, 16:30
Spot on. Power steering line is corroded and leaking. I'm taking it back to the garage that did the work on it last week as I'm sure its no coincidence that the leak started after they replaced the track rod just below this pipe. Still don't know why the power steering fluid level hasn't dropped. Maybe it was over filled to start with.
(https://s18.postimg.org/fwrr2kbnd/Leak.jpg)
Not sure I like the look of the steering UJ either but the steering seems to be fine so I'll leave it just now.
Post by: Wabbitkilla on May 30, 2017, 16:33
To be fair those pipes are realy crusty and it was only a matter of time before they failed, I wouldn't blame the garage.
Post by: cptspaulding on May 30, 2017, 17:04
I tend to agree with Wabbitkilla. They're a common failure on our cars at this age.
Post by: Myles1ZZ on May 31, 2017, 08:47
Yeah, looking at them I suppose it was only a matter of time. Running without the front nappy probably hasn't helped! Might be an idea to look into getting one from Mr T.
Post by: Joesson on May 31, 2017, 09:14
My belief is that there is very little fitted to cars  that does not serve a useful or aesthetic function, with the exception of the passenger window disable switch on the 2.
It might be to do with what we call the " nappy" would you admit to having one?
If we called it an undertray or anti crud shield maybe we would be happier keeping them where Mr T intended.
Post by: Carolyn on May 31, 2017, 09:41
Quote from: "Myles1ZZ"Yeah, looking at them I suppose it was only a matter of time. Running without the front nappy probably hasn't helped! Might be an idea to look into getting one from Mr T.
Get in touch with Rutland MR2 - save mucho.
Post by: Myles1ZZ on May 31, 2017, 16:53
I take it these are the correct aftermarket replacements: http://www.ebay.co.uk/itm/322177470625 (Got the link from another thread). Mr T wanted £350   s:flame: :flame: s:flame:
Would I need to bleed the power steering system after fitting or would it be good enough to make sure the pipes are full of fluid when fitting? I hear bleeding the PS is a right pain.
Post by: Myles1ZZ on May 31, 2017, 17:31
Argh! Where can you buy the proper power steering fluid? It should be part 08886-01206 but everywhere I check it is listed as discontinued??? From what I have read non toyota stuff is a recipe for a ruined pump.
What does everyone else use?
Thanks!
Post by: Myles1ZZ on May 31, 2017, 18:10
Sorry to spam posts but has anyone tried this stuff: http://www.ravenol-direct.uk/ravenol-e-psf-fluid.html ? It claims to meet the Toyota 08886-01206 standard and is only £12.99 a litre! Too good to be true   s:?: :?: s:?:
Post by: Carolyn on May 31, 2017, 19:39
It would be my choice.  If it's not Toyota compatible, that would be a very big lie and they would have been exposed by now.
Post by: tomaky on May 31, 2017, 19:43
Thats PS pipes first they weep before total failure.
