The Workshop => Maintenance, Problems & Troubleshooting => Topic started by: Reeflodge on June 26, 2017, 14:59
Title: Chain Tensioner Oil Leak
Post by: Reeflodge on June 26, 2017, 14:59
I think my Chain tensioner is leaking again.
I replaced the seal with a new one from MrT 2 months again but it looks as though its leaking again as there was a small oil puddle on my garage floor a week after we went on a 240 mile road trip.
Is it recommended to put a bit of silicone on the face plate when fitting?
Title: Re: Chain Tensioner Oil Leak
Post by: Carolyn on June 26, 2017, 15:35
The trick is not to use the Toyota O ring.  Use an imperial size - works out as 21.82 mm x 3.53 mm in metric.  They are available from Sealforce (you can find them on ebay). I use the Viton ones.
I've got two left, so I can send you one.
PM me your address.
BTW: Have a look to see if it's oily directly below the tensioner on the engine.  Just to be sure the drip isn't coming from somewhere else.
Post by: Reeflodge on June 26, 2017, 15:40
Hi Carolyn
Yesd the oil is fresh & clean just by the tensioner plate and gets dirty towards the bottom of the engine.
I cant see where else it could be coming from!
PM sent
Post by: ilovejapcrap on June 26, 2017, 17:29
great little tip Carolyn.
is this the one ?
 m http://www.ebay.co.uk/itm/BS212FEP-V-21 ... Sw1BlZRS~q (http://www.ebay.co.uk/itm/BS212FEP-V-21-82-x-3-53mm-FEP-Viton-Core-BLACK-Pack-of-1-/222550383620?hash=item33d1095c04:g:rAoAAOSw1BlZRS~q) m
Post by: Carolyn on June 26, 2017, 17:51
This one
 m http://www.ebay.co.uk/itm/IMPERIAL-VITO ... 2749.l2649 (http://www.ebay.co.uk/itm/IMPERIAL-VITON-90-SHORE-RUBBER-O-RINGS-3-53MM-CROSS-SECTION-BS201-BS231/371920009130?ssPageName=STRK%3AMEBIDX%3AIT&var=640866107433&_trksid=p2060353.m2749.l2649) m
Post by: Carolyn on June 26, 2017, 17:59
Search for O rings on Ebay.  Look for Sealforce, go to their shop.
Mind you, I've just ordered ten more.  so you could ask me for one.
