The Workshop => Maintenance, Problems & Troubleshooting => Topic started by: rokz_2005 on October 13, 2017, 12:12
Title: Transponder key amplifier location
Post by: rokz_2005 on October 13, 2017, 12:12
Hi,
Can someone please tell me where I can find the transponder key amplifier? Referred to as T2 on the electrical schematics.
Title: Re: Transponder key amplifier location
Post by: paulj on October 13, 2017, 17:18
On the diagram it shows near to I10 (ignition switch) so you should find it somewhere in the steering column area.  If my wiring diagram is right it has 5 wires to it - black, yellow, white/black, yellow/blue and black/blue.
Good luck with the hunt
Post by: rokz_2005 on October 13, 2017, 17:19
Quote from: "paulj"On the diagram it shows near to I10 (ignition switch) so you should find it somewhere in the steering column area.  If my wiring diagram is right it has 5 wires to it - black, yellow, white/black, yellow/blue and black/blue.
Thanks Paul. It's resolved. It's built into the coil receiver pack. Just spoke to Toyota.
