The Workshop => Maintenance, Problems & Troubleshooting => Topic started by: MR2Adam on November 14, 2017, 17:13
Title: MK3 Gear Cage Mounts
Post by: MR2Adam on November 14, 2017, 17:13
Been hearing only good things about fitting solid mounts to the gear cage replacing the rubber mounts.
But I can't find the solid mounts on their own online anywhere. Does anyone have any links or suggestions?
Title: Re: MK3 Gear Cage Mounts
Post by: J03 on November 14, 2017, 19:54
I have a spare set here with bolts you can have for, say a tenner posted?
Post by: MR2Adam on November 14, 2017, 21:29
I'm guessing it's just the four stainless mounts?
If so I'm down for that
Post by: J03 on November 14, 2017, 22:05
Yes 4x solid alu mounts & 4x bolts.
I'll just add that these are solid mounts from a short shifter kit, so they raise the cradle to compensate. This shouldn't be a problem, but it will mean your shift sits 14mm higher.
(http://i.imgur.com/RytdSlC.jpg) (http://imgur.com/RytdSlC)
Post by: MR2Adam on November 14, 2017, 22:37
Even better with a slight raise. Yeah I've seen other owners fit just the mounts/spacers.
Just drop me a private message and I'll have them.
Post by: J03 on November 14, 2017, 23:05
Will do & I'll update the thread afterwards.
Post by: J03 on November 14, 2017, 23:32
Payment received, cheers.
