The Workshop => Maintenance, Problems & Troubleshooting => Topic started by: smarty72 on November 18, 2017, 12:42
Title: Prius fog lamps?
Post by: smarty72 on November 18, 2017, 12:42
I'm sure I read somewhere that the fog lights fitted to the Prius (2003 to 2009) are compatible with the roadster's?
If so, has anyone tried any of these?
 m https://m.ebay.co.uk/itm/For-Toyota-Pri ... SwcUBYLWA7 (https://m.ebay.co.uk/itm/For-Toyota-Prius-2003-2009-Front-Bumper-Fog-Lights-Right-Left-RH-LH-Assembly/381861417410?hash=item58e8b6d1c2:g:vxwAAOSwcUBYLWA7) m
And if you did, is the price too good to be true?
Title: Re: Prius fog lamps?
Post by: Ardent on November 18, 2017, 17:36
Havn't tried them as got mine as group buy on here.
But I concur with what you say.
Post by: smarty72 on November 18, 2017, 17:58
Concur with which bit?
That they will fit or they are too cheap to be any good (or maybe both)?
Post by: Ardent on November 18, 2017, 23:20
the fit bit
Post by: Call the midlife! on November 18, 2017, 23:45
If you use the vehicle checker at the top the computer says no...
Having said that I've got a Rover 400 armrest fitted to mine and I'm damn sure the computer would say no to that too.
Post by: smarty72 on November 19, 2017, 07:02
Quote from: "Call the midlife!"If you use the vehicle checker at the top the computer says no...
Indeed it does (I had tried that) but this seller claims his fog lamp fits both vehicles;
 m https://m.ebay.co.uk/itm/Toyota-Prius-2 ... SwjL5ZNIRL (https://m.ebay.co.uk/itm/Toyota-Prius-2003-2009-MR-2-2000-2005-Drivers-Side-Front-Fog-Lamp-Fog-Light/301243982695?epid=650297970&hash=item46238a6367:g:uGAAAOSwjL5ZNIRL) m
Post by: Peter Wright on November 19, 2017, 08:58
Toyota MR2 Roadster UK RHD Part Numbers
RH
81211-52060      1   € 123.88
LH
81221-52060      1   € 123.88
I dont know why different part numbers as I thought they were both the same items
Pete
Post by: Call the midlife! on November 19, 2017, 09:00
Maybe he just surface mounts them, old school style?[emoji2]
Post by: smarty72 on November 19, 2017, 09:43
Quote from: "Peter Wright"Toyota MR2 Roadster UK RHD Part Numbers
RH
LH
Pete
Thanks Pete.
They look to be 'handed' in the images.
Just used carparts4less website entering details for a 2007 Prius and my MR2 - they list exactly the same lamps, so I think they will fit.
Now just need to decide whether to take a punt on a cheap item from China??
Post by: hamspeed on November 19, 2017, 13:53
To confirm - the OEM part is the same, they also fit a few other US market vehicles such as the Highlander, Scion etc...
I run a group buy/supply on the forum. It took me a couple of samples to find a decent product, so approach it with the mindset "you get what you pay for."
Two of the biggest issues I came across whilst:
- Bulbs not seating correctly due to the moulding of the housing (allowing water ingress.)
- Front glass not bonded substantially enough
- Damaged upon arrival
It's also worth noting that you will also have to pay customs and VAT at 20% upon arrival (unless the seller does not fill the paperwork out correctly of course!)
Post by: smarty72 on November 19, 2017, 14:00
Quote from: "hamspeed"To confirm - the OEM part is the same, they also fit a few other US market vehicles such as the Highlander, Scion etc...
Thanks Hamish, I'm aware of your lamps which look great and I really would like some for the DRL functionality - just not wanting to spend that much atm.
Mine look hideous and I very rarely use them, just thought it might be a cheap solution to smarten them up.
I'll have a think and see if Santa (Mrs S) wants to place an order for a pair of yours.
