The Workshop => Performance Related => Topic started by: KRAMSNEHPETS on February 23, 2018, 22:07
Title: Miester R CRD
Post by: KRAMSNEHPETS on February 23, 2018, 22:07
Collected car last night after having the above fitted . Just waiting for some dry roads to see what they are like!
Title: Re: Miester R CRD
Post by: AndPow68 on February 26, 2018, 19:07
I'm really interested in your update as I'm looking to swap out stock suspension in the next 3-6 months.
Post by: KRAMSNEHPETS on February 26, 2018, 20:37
Weather permitting , I have a 140 drive to do on sat
Post by: Nvy on March 15, 2018, 10:50
I do have them on my civic for a year and i like them. Everything depends on what you are using the car for, if you are not doing track days id go for progressive springs coz they take the potholes and uneven roads better than the linear ones. Also coils are a bit hard to get the best out of them coz they require a lot of settings. And when you add the noticeable more road noise these are not worth it if you are not driving it on the track.
Post by: 1979scotte on March 15, 2018, 13:11
Quote from: Nvy on March 15, 2018, 10:50
Couldn't disagree more tbh.
I wouldn't got back to stock or lowering springs.
What I have lost in ride comfort I have gained in handling on all but the worst surfaces.
Post by: Nvy on March 15, 2018, 14:32
Quote from: 1979scotte on March 15, 2018, 13:11
Im talking about my experience with the Civic, ofc the toyota is lighter and could be a lot better than the Civic. I also had progressive lowering springs that i found better on bad roads and over speed bumps. Like i said i like the coils but its not only coils that need doing for better handling but things like fast road setup, tires and wheels combo and so on. What i didnt like is the added road noise but that u can get used to.
Post by: Call the midlife! on March 15, 2018, 15:38
Don't be swayed by your first few drives, give them time to settle in (check all round for tightness after a few drives too) then start playing around with the settings until you're happy with how you want them.
Set them up against your tyres etc and the loading on your car, you'll be glad you did.
Post by: KRAMSNEHPETS on March 15, 2018, 21:31
Did a 140 drive but roads were damp and mainly motorway. going to one of my motors port customers in a weeks time to get it all set up, weighted etc
Post by: Call the midlife! on March 15, 2018, 22:03
Quote from: KRAMSNEHPETS on March 15, 2018, 21:31
Corner weighted? Saucy!
Post by: KRAMSNEHPETS on March 16, 2018, 22:10
will be interesting to drive after
Post by: BahnStormer on March 20, 2018, 14:32
What is the drive comfort like afterwards? I'm seriously considering the same Coilovers on mine, but I use it one a nearly daily basis for commuting and it is a lot of country lanes that are far from perfect, so nervous about rattling my brain to pieces! I was thinking the MeisterR's but on the softest setting (they are ride+height adjustable, aren't they?!?)....
Post by: Call the midlife! on March 20, 2018, 17:56
Quote from: BahnStormer on March 20, 2018, 14:32
32 clicks of damping adjustment but mine are "bouncy" at the lowest setting, rough country lanes aren't as bad as dropping off the other side of speed bumps.
Post by: KRAMSNEHPETS on March 22, 2018, 01:30
Wouldn't want them as a daily drive...
Post by: Beachbum957 on March 23, 2018, 10:23
Quote from: KRAMSNEHPETS on March 22, 2018, 01:30
Please elaborate.  How are the Meister R compared to what you ran previously?
Post by: 1979scotte on March 23, 2018, 15:45
Quote from: Beachbum957 on March 23, 2018, 10:23
I have run meister R on 2 different roadsters.
They're stiff no doubt about it but then so are all the coilover options.
For me it is well worth the sacrifice in ride comfort very little roll and much quicker turn  in are just 2 of the pluses but I don't use mine everyday and certainly don't commute in it.
You need to get your bum in a seat of a car with them fitted and Tein and BC too if you can.
Even then a quick test drive doesn't necessarily tell the full picture.
