The Workshop => Maintenance, Problems & Troubleshooting => Topic started by: Carolyn on March 9, 2018, 11:23
Title: In-car cylinder head gasket job
Post by: Carolyn on March 9, 2018, 11:23
Well, I've just done one of these.
Won't be repeating the exercise.
I would have been much better off dropping the engine.
Title: Re: In-car cylinder head gasket job
Post by: jonbill on March 9, 2018, 11:51
Bit of a sod was it, putting the bolts back in?
Post by: Carolyn on March 9, 2018, 12:06
It was all the little stuff - and figuring out how to get that hose back on.  Just so fiddly.
Could have done it in half the time and with a lot less frustration with it on the floor.
Post by: jonbill on March 9, 2018, 18:24
I thought the hose wouldn't ofhave been a problem, my money was on the inlet manifold bolts.
Anyway, is it going right now?
Post by: Ardent on March 9, 2018, 18:29
Quote from: jonbill on March  9, 2018, 18:24
Never even though of that. I bailed out on the OCV.
Do not have triple jointed wrists.
Post by: Carolyn on March 9, 2018, 18:48
Had to place the head on wooden blocks, get the hose on (using jubilee clip) and fiddle the head gasket into place while holding the head.  Not easy single handed.
Should run tomorrow.  Cams are in. Just a couple of bits and coolant....
That hose doesn't exist on an MR S.  Just wondering if you OF the oil heater.  In which case you've got a replacement engine...
Next time you're here, I'll give you the blow-by-blow.
How's yours doing?
Jason: getting the machine screw into the OCV is, indeed. a proper piglet.
Post by: jonbill on March 9, 2018, 19:06
If you want a hand tomorrow I can come over.
I ofn't done much with mine TBH, mainly been putting the Z engine together again. If it's dry tomorrow I'll have a go at cleaning the glue off where the skirts and scoops were.
I think I did see an oil heater when I was under, but could be wrong.
Post by: Carolyn on March 9, 2018, 19:09
I'm fine, but always good to see you.
If you do come by, I need to give you some kero.
Post by: Carolyn on March 11, 2018, 10:43
Job done.
Started and running.  No leaks, no drips no crap coming out of the tailpipe.  Engine (discounting exhaust and super charger) super quiet.  Which is nice.
Never again.
Post by: jonbill on March 11, 2018, 12:45
Did I read you've got it in somewhere for rr mapping?
