The Workshop => Maintenance, Problems & Troubleshooting => Topic started by: michaelb on March 22, 2018, 22:29
Title: Removing side vents
Post by: michaelb on March 22, 2018, 22:29
Hi guys, what's the best way to remove the side vents, without breaking the clips? Cheers
Title: Re: Removing side vents
Post by: delhusband on March 22, 2018, 22:39
Following with interest, Tried once and failed - was trying to get inside to push out dent in panel from inside
Post by: Call the midlife! on March 22, 2018, 23:03
Even if you do remove it without breaking them they'll fall off into the inner wing!
They get old and brittle, especially in the cold weather, you could try warming them up a bit first, or just treat them as consumables and keep some spares to hand. They're cheap enough to buy new.
Post by: StuC on March 22, 2018, 23:10
Flat bladed screwdriver with tape on (to protect paint) slow even pressure and wait for the pop.
Couple of tips:
Try and avoid in cold weather, the plastic is more brittle when cold.
Also, bear in mind that most if these clips are 10 years +, having endured lots of extremes of temperature. There is a high chance of them breaking even with a gentle touch.
Post by: StuC on March 22, 2018, 23:11
Quote from: Call the midlife! on March 22, 2018, 23:03
Beat me to it!! I spent too long typing. Lol
Post by: Call the midlife! on March 22, 2018, 23:14
Quote from: StuC on March 22, 2018, 23:11
Haha! I've already moved on since then too! I've seen folk demonstrate removing them on YouTube by just getting their fingers under the back edge and ripping them off!
I bought a selection of trim removal tools (notched plastic pry bars etc) and they're fairly successful.
Post by: michaelb on March 23, 2018, 07:32
Where would you get your hands on new clips?
Post by: Call the midlife! on March 23, 2018, 07:37
Quote from: michaelb on March 23, 2018, 07:32
Fleabay is usually ok or vehicleclips.co.uk (I think, try a few variations) I got some a few weeks back I'll see if I kept the details but a lot of the trim clips are universal across the Toyota range.
Post by: michaelb on March 23, 2018, 09:04
Ok, many thanks mate
Post by: Call the midlife! on March 23, 2018, 09:57
Quote from: michaelb on March 23, 2018, 09:04
No bother mate, I've looked back but can't see the details of the ones I ordered and I've had 3 different sets over winter [emoji23]
Post by: michaelb on March 23, 2018, 10:03
It's ok, I found them on fleabay, cheers
