The Academy => How To's => Topic started by: shnazzle on April 20, 2018, 21:37
Title: Valve Clearance Adjustment and Cam Timing
Post by: shnazzle on April 20, 2018, 21:37
How To: Adjust valve clearances and time the cams
by Carolyn
Pending details and pics
THIS IS NOT A JOB FOR A TOTAL BEGINNER.  YOU NEED ADEQUATE TOOLS AND A DECENT LEVEL OF SKILL FOR THIS ONE.
If you think the top end of your engine is too rattly and you want to quiet it down:
I'd start by changing the chain tensioner.  (This is covered in another 'How To').  They do get old and worn.  It can make a massive difference to top end noise at low rpm.
If you're still not happy, you will have to measure all your valve clearances and note them down.  Remove the cam cover and measure the gaps when the cam lobes are up.  This is fiddly.  Helps to have a couple of sets of feeler gauges so you can measure each one twice without having to fiddle with changing feeler blades.  You'll have to rotate the engine to measure them all.  I use a short 19 mm socket and ratchet on the crank, but you can use the 14 mm bolt on the centre of the vvti hub or, if you have room, put it it high gear and roll using the rear tyre.  Rotate clockwise (removing the spark plugs makes rotating and positioning a lot easier). Make up a 'table' for noting gaps and (later) bucket thicknesses.
(https://uploads.tapatalk-cdn.com/20180919/f0164712f8c61b0870180476d9419acc.jpg)
(https://uploads.tapatalk-cdn.com/20180919/9bc13a8f531c8160bc0be2b555f74301.jpg)
Don't even ask about the chain!!!
This pic shows a timing issue. The engine is at TDC correctly but the timing marks on the insides of the sprockets are not lining up exactly. This needs to be fixed so that they line up, before you continue
(https://uploads.tapatalk-cdn.com/20180919/fe183a5a6a69c43759001c49a18c1a3e.jpg)
This shows correct timing. Engine at TDC again but this time the dots line up perfectly.
The fact that the chain markers don't align at the top doesn't matter to timing.  You can see the cam lobes on #1 cylinder are both up and pointing at each other.  This means the engine is at TDC on cylinder #1. (Which is the correct position.
(https://uploads.tapatalk-cdn.com/20180918/bc12ba59dbf7718d74f3a0bb2794af4b.jpg)
(https://uploads.tapatalk-cdn.com/20180919/0915c1453f7de02e28cfc78315bcd01c.jpg)
Also attached is a pic of using an adjustable spanner on the camshaft.  This is important for both tightening and positioning.
