The Workshop => Maintenance, Problems & Troubleshooting => Topic started by: michaelb on May 22, 2018, 19:40
Title: Cleaning MAF
Post by: michaelb on May 22, 2018, 19:40
What's the best way to clean the MAF sensor? I've never done it but believe it can make the car run a bit better?
Title: Re: Cleaning MAF
Post by: dan944 on May 22, 2018, 19:44
Scroll down a bit to the cleaning maf section. Looooads of input on this.
Post by: paulj on May 22, 2018, 20:34
What you need to clean is a thin wire, clean it with contact spray only and don't touch it.  There is a thicker wire with a bulb which is also worth a spray of cleaner but you haven't finished the job until the thin one is done.  It hides well into the body of the MAF.
Post by: michaelb on May 22, 2018, 23:00
Ok cheers!
