The Workshop => Performance Related => Topic started by: BahnStormer on July 8, 2018, 08:25
Title: How to setup cam bolts?
Post by: BahnStormer on July 8, 2018, 08:25
Can I check how to setup Eibach easy-cam bolts?
https://eibach.com/us/i-6266-pro-alignment-camber-bolt-kit.html
I took mine in for an alignment check straight after installing the coilovers and I've been told that I've set mine up incorrectly in several ways: the adjustment washer is on the wrong side (should apparently be on the bolt side, NOT the nut), which does make sense, the main bit that I wanted to check on is the bolts: Apparently the cam adjustment bolts should be in the TOP, not bottom?
The camber is apparently almost exactly on stock setup, so perfectly drivable, but I just want to get it sorted before if gets too much corrosion on that and it all becomes 10x more difficult!
Title: Re: How to setup cam bolts?
Post by: BahnStormer on July 9, 2018, 10:41
Is this better suited in the maintenance, problems and trouble-shooting part of the forum?
Post by: wotugonado on July 9, 2018, 12:15
@BahnStormer (https://www.mr2roc.org/forum/index.php?action=profile;u=24604)
It's official you've had a mare  :) Power flex instructions below
(https://i.imgur.com/UyUP562.jpg)
Post by: BahnStormer on July 9, 2018, 15:43
Oh balls... Yep figured as much :(
Thanks though @ wotugonado
Post by: wotugonado on July 9, 2018, 22:31
No problem.......
Post by: james_ly on July 10, 2018, 10:15
Is camber adjustable on the top mounts as well?
Post by: jvanzyl on July 10, 2018, 10:25
Not on the rears.
Post by: BahnStormer on July 10, 2018, 10:39
Quote from: james_ly on July 10, 2018, 10:15
nope - not for the rears: Camber adjustment is only via the bolts... the fronts have camber adjustment on the topmounts though.
One other thing I noticed: the OEM torque settings are 173Nm... but it looks like the Powerflex ones max out at 122Nm and everything I can find relating to the Eibach ones indicated 80Nm-120Nm, so either way, I think my camber bolts are seriously over-torqued  :o
Do you think I'm okay to leave them for another 3 weeks (a few hundred miles)?!? I know the camber is OEM spec now, so I was only going to swap them back the day before I'm due to go back to WIM (28 July).
Post by: str160 on July 10, 2018, 14:26
Quote from: BahnStormer on July 10, 2018, 10:39
Really? How? I had mine apart at the weekend and didn't see anything there that would indicate adjustment.
Post by: Call the midlife! on July 10, 2018, 14:29
Quote from: str160 on July 10, 2018, 14:26
Possibly talking about coilovers which often have adjustable top mounts.
Post by: str160 on July 10, 2018, 14:31
Quote from: Call the midlife! on July 10, 2018, 14:29
Ah, missed that.
Post by: BahnStormer on July 10, 2018, 14:37
The photo at the top is of a rear BC Racing Coilover with new droplinks and incorrectly installed Eibach EZ Cam adjustment bolts.
Regarding fronts: they are the same BC Racing coilovers - this photo is a Google-images search for something that just looks a bit like mine - so this isn't an MR2 - the topmount plate is a slightly different shape, but the centre adjustments look exactly like this...
Post by: BahnStormer on July 10, 2018, 14:41
Yep this is all about coilovers....
Quote from: BahnStormer on July  8, 2018, 08:25
