The Workshop => Appearance Related => Topic started by: FuZZy_gr on August 15, 2018, 13:41
Title: Gt300 hood replica
Post by: FuZZy_gr on August 15, 2018, 13:41
Hello guys im in the process of modifing my hood into a gt300 style and wanted to share the quest with you!
(http://i63.tinypic.com/rw5bbq.jpg)
(http://i63.tinypic.com/24ovl2o.jpg)
(http://i68.tinypic.com/2u7u15e.jpg)
(http://i68.tinypic.com/2aj8bwl.jpg)
(http://i67.tinypic.com/b3so6o.jpg)
Title: Re: Gt300 hood replica
Post by: Treboeth on August 15, 2018, 13:48
You had me confused for a minute, I thought "how can you customise a hood".
Then I saw your bonnet ;)
Looks very nice :)
Post by: lamcote on August 15, 2018, 13:57
Quote from: Treboeth on August 15, 2018, 13:48
Or did you?
Definition of bonnet = "the hinged metal canopy covering the engine of a motor vehicle"
Post by: FuZZy_gr on August 15, 2018, 18:57
Well i think its called front hood if my english are right!
Post by: Joesson on August 15, 2018, 22:22
The hood (North American English) or bonnet (Commonwealth English excluding Canada) is the hinged cover over the engine of motor vehicles that allows access to the engine compartment (or trunk on rear-engine and some mid-engine vehicles) for maintenance and repair. In British terminology, hood refers to a fabric cover over the passenger compartment of the car (known as the 'top' in the US). In many motor vehicles built in the 1930s and 1940s, the resemblance to an actual hood or bonnet is clear when open and viewed head-on; in modern vehicles it continues to serve the same purpose but no longer resembles a head covering.
Wikipedia.
Well, that clears that up doesn't it !
Post by: The Other Stu on August 15, 2018, 22:37
According to a bloke on Facebook, it's no longer a frunk.
It's now called a froot.
Post by: a on August 16, 2018, 05:34
Very nice.
Post by: 1979scotte on August 16, 2018, 07:08
Quote from: The Other Stu on August 15, 2018, 22:37
It's been called a froot for ages.
Pretty sure we invented it.
Post by: Joesson on August 16, 2018, 07:51
Pretty sure we did.
@UKTotty 05 September 2010 "It was early. Anyway that is the froot front boot"
NB auto correct or whatever, and myself are totally confused.
The member I am referring to is known as uktotty in UPPER or lower case or a mix of the two.
Post by: Joesson on August 16, 2018, 08:14
@shnazzle (https://www.mr2roc.org/forum/index.php?action=profile;u=18356)
I used the " search" function for "froot".
On the first occassion There were 8 references, the earliest was attributed to uktotty on 05 September 2010.
I tried to copy and paste the reference without succeso.
Entered my response from my memory and when I went back there where only 3 ( current) references!
I also tried to find UKtotty on the Member search but now realise it should be high I will correct on my response.
I guess this is just some quirk of the system, or maybe, as is often in my case User Error.
Post by: The Other Stu on August 16, 2018, 11:41
Quote from: Joesson on August 16, 2018, 08:14
PICNIC is the term we use.
Problem in chair, not in computer.
Post by: Joesson on August 16, 2018, 12:10
@The Other Stu (https://www.mr2roc.org/forum/index.php?action=profile;u=23604) - Thanks Stu,
So all my ( Computing ) problems will be solved if I STAND UP when I'm 'puting!
Post by: delhusband on August 16, 2018, 13:38
I've been told error code 1D10T is what IT dudes find when called by PICNICs  ;)
Post by: FuZZy_gr on September 5, 2018, 13:59
(http://i66.tinypic.com/2vcvuxh.jpg)
Post by: Topdownman on September 5, 2018, 15:59
Thats a very tidy looking job there, nice paint too!
Post by: shnazzle on September 5, 2018, 23:06
That's well done that is
Post by: tatieu on September 6, 2018, 11:31
I like it !  :notworthy:
Post by: FuZZy_gr on September 6, 2018, 12:56
Well i m not 100% happy but next will be perfect !  :D :D
Post by: rokz_2005 on October 1, 2018, 18:38
Nice job man.
Post by: Ardent on October 1, 2018, 19:58
Loving the smoked lights.
The vents are a bit aggressive for my taste.
But, nicely done all the same.
Works as a package.
Stealthy.
