I've got an occasional whining/beeping when the AC is on, which is pretty much always.
It's not the fan motor because it only does it when A/C is active.
Anybody had this?
It's not The Wife telling you it's too "beeping" cold then??
Quote from: Call the midlife! on January 6, 2019, 20:38
"beeping" is southern. Up north we have more of an exclamation
Quote from: shnazzle on January 6, 2019, 20:51
Yeah, I'm from Yorkshire, it's got to be pretty strong to warrant "beeping" round here!
Compressor / clutch? Though I don't know what would be beeping?
If you're concerned there's a local specialist, I think I posted their details up in the garage section.
Quote from: Bossworld on January 6, 2019, 21:22
Not really concerned. It's intermittent at the minute but if it gets more frequent I will need to have a deeper look.
Just checking if someone had experience with this.
It's quite a loud beep.
Quote from: shnazzle on January 6, 2019, 21:36
Simple solution....move further north across the border....you'll get get to the Dreadnought Garage / Knockhill track nights and you won't need to use your air con [emoji4]
Alarm Sounder beep or Dash beep? i.e. Is it the same beep/same source you get when attempting locking the car with door open? You say it's quite loud, mine's quiet but I haven't done the alarm move mod. Or is it the dash sounder (i.e. Something left on passenger seat with seatbelt undone)? Or is it summary else? I'm asking like I have an answer - sadly I'm just being nosey and hoping this'll maybe not an idea with someone else :-[
Quote from: Dougster7 on January 8, 2019, 22:19
I will get there at some point!
Quote from: delhusband on January 8, 2019, 23:48
No its not a noise from a speaker. It's more mechanical or an air whistle
Sounds silly, I know. You could try cleaning the belt and the pulley grooves. It might be that it only makes belt noise under load....
Only a possibility, but an easy job?
Quote from: Carolyn on January 9, 2019, 10:16
That was my first thought but upon exiting the car and listening in the engine bay the noise was gone. It's definitely coming from the cabin. So I can only suspect the cooling unit. All I know is that it's a big mass under the passenger dash, so I have no idea how it works or what it's made of.
The pitch doesn't change either. And it's immediate on pressing the AC button. Could be an electric buzz from a relay as well
Could be wrong but sounds like one of the teeth or more for the spinning cogs/motor have broken off which is causing that to happen. When it slips, it's causing the noise.
Quote from: ossy on January 9, 2019, 14:25
Hmm could be. It's more of a continuous tone
It sounds like a noisy solenoid. But looking at the diagrams I have - there isn't one.
There's a powerful relay that switches the clutch in the engine compartment relay box (the one behind the battery.
There's also a couple of relays on the fan unit under the dash.
Got a stethoscope?
Quote from: Carolyn on January 9, 2019, 15:46
Got a stethoscope?
Yeah I suspect relay to be honest
