Good Morning all
Does anyone know if you could use the PFL 15 inch rear wheels with 225/45/15 tyres or will they be too wide to fit .
The rear PFL wheel is the below spec
Rear Wheels
Width 15″ x 6.5″
Offset = et45
PCD = 4 x 100
The FL rear wheel is the below spec and is fine with 224/45/16 .
Rear Wheels
Width 16″ x 7″
Offset = et45
PCD = 4 x 100
Rim min optimal max
5,0 155 165 or 175 185
5,5 165 175 or 185 195
6,0 175 185 or 195 205
6,5 185 195 or 205 215
7,0 195 205 or 215 225
7,5 205 215 or 225 235
8,0 215 225 or 235 245
8,5 225 235 or 245 255
Easier stil:
https://www.tyresizecalculator.com/tyre-wheel-calculators/tyre-size-for-rim-size-width-calculator
Ok so 215 is the max it looks like .
Regards
I sold my facelift wheels for £50, so it should be easy to get some cheap.
Just thinking of going to PFL 15 inch in 195/50/15 front and 205/50/15 rear .
The set up I have at the moment is 195/50/15 front and 225/45/16 rear .
Car is for track work only .
Quote from: james_ly on January 31, 2019, 13:35
The 15" wheel is a bit lighter, but narrower tyre gives less grip at the rear, so it really depends what you want to achieve. I like the handling with less grip personally, but I'm weird and run cheap tyres on purpose :)
