The Workshop => Maintenance, Problems & Troubleshooting => Topic started by: MR2Adam on June 17, 2019, 21:41
Title: Lower UJ Removal
Post by: MR2Adam on June 17, 2019, 21:41
It's new lower uj time.
Any advice on removing the UJ? Especially separating the splines at the bottom, what's the best method?
Title: Re: Lower UJ Removal
Post by: Bossworld on June 17, 2019, 23:10
Quote from: MR2Adam on June 17, 2019, 21:41It's new lower uj time.
There is probably a guide on here but plenty of plusgas/penetrating oil, undo the bolt at the rack, undo the bolt at the top so you can move the whole thing upwards. (believe some people loosen the upper UJ for more space but I decided against it).
Tapped it steadily with a hammer, upwards and away from the rack. Also intermittently used a sturdy flat headed screwdriver to try and ease the clamp apart too.
Edit : here you go
https://www.mr2roc.org/forum/index.php?topic=32611.0
