The Workshop => General => Topic started by: a on September 29, 2019, 20:29
Title: Turbo nearly fitted
Post by: a on September 29, 2019, 20:29
Bought as a kit from Rayn2016 on here 10 months ago.
After sorting through all the bits (50% is crap).
Getting there though.
Title: Re: Turbo nearly fitted
Post by: s12vea on September 29, 2019, 20:34
Nice to see a project coming along nicely, interesting place for airbox.
Keep the updates coming
Post by: a on September 29, 2019, 21:38
Quote from: s12vea on September 29, 2019, 20:34Nice to see a project coming along nicely, interesting place for airbox.
Yes wanted to use the original airbox at this stage and that's
the only place it would fit,with a slight mod.
Post by: s12vea on September 29, 2019, 22:07
I like the look of that
Post by: a on October 12, 2019, 16:57
Up and running! :)
Post by: Ardent on October 12, 2019, 22:47
Pics? Vids? Audio?
Post by: a on October 13, 2019, 09:48
bought like this
and now:
Very interesting build as I had no clue at the start!
Post by: Gaz2405 on October 13, 2019, 10:01
Ahh Apexi PFC, would be interesting to compare maps, base, ign, vvti etc and full specs of injectors, boost levels.
Post by: Petrus on October 13, 2019, 11:38
A word of caution.
TTE strongly warns against ány obstructing of the side vent entries when fitting a turbo.
Also that a heat shield above the turbo/exhaust is essential.
A fan with thermostat under the engine lid seems to be a must.
Post by: househead on October 13, 2019, 11:48
Quote from: shiny on October 13, 2019, 09:48Very interesting build as I had no clue at the start!
Nice work! Provides hope for some of us.
Hope you're enjoying the extra power!
Post by: 1979scotte on October 13, 2019, 12:51
Quote from: Petrus on October 13, 2019, 11:38A word of caution.
Plenty of cars run without heat shields no worries.
My aftermarket fan caused as many issues as it cured.
Although intake and engine bay temps did make me rule out a turbo for the V6 opting instead for the rotrex.
Post by: Petrus on October 13, 2019, 13:53
Quote from: 1979scotte on October 13, 2019, 12:51Plenty of cars run without heat shields no worries.
AH well, Toyota seems to have a fetish about them in our Spyder....
QuoteMy aftermarket fan caused as many issues as it cured.
Good point. Can imagine that.
QuoteAlthough intake and engine bay temps did make me rule out a turbo for the V6 opting instead for the rotrex.
I have noooooo trouble understanding that :-)
Post by: a on October 13, 2019, 17:40
Quote from: househead on October 13, 2019, 11:48
Thanks for the reply househead
Post by: s12vea on October 13, 2019, 17:44
How does it drive?
Post by: a on October 13, 2019, 17:51
The battery would be obstructing the side vent if that's what you mean? Plenty
of gaps for the air still to flow.
I have two 180mm fans ready to be installed if needed just need to source a thermostatic switch.
Just driven it down the street, appears to pull well and the AFR is between 11 and idle at 15.
Happy so far
Post by: Petrus on October 13, 2019, 18:12
Quote from: shiny on October 13, 2019, 17:51
Happy so far
First things first; even for someone wíth a clue at the start you seem to made a really neat install.
I thought the OEM box (véry clever to use that) was sitting on the battery´s place and it is bulkier.
The proof of the cooling is in the driving though :-)
Good to read you are prepared if that pudding gets a bit too hot.
Chapeau to you!
Post by: thetyrant on October 13, 2019, 19:43
Nice work, hopefully get started on my turbo install this week :D
Post by: a on October 14, 2019, 17:28
Aftermarket fans what are the issues?
Post by: 1979scotte on October 14, 2019, 19:51
Quote from: shiny on October 14, 2019, 17:28
Making sure they don't melt for a start.
Getting them setup right.
So they don't spend all they're time on.
Post by: a on October 14, 2019, 20:05
Quote from: 1979scotte on October 14, 2019, 19:51
Cheers scotte. So a thermostatic switch/controller would be ideal?
Post by: 1979scotte on October 14, 2019, 20:26
Quote from: shiny on October 14, 2019, 20:05
It's a must
Post by: Petrus on October 15, 2019, 08:47
Quote from: 1979scotte on October 14, 2019, 19:51Making sure they don't melt for a start.
If ever there was an illustration of the heat the exhaust side radiates....
Lóve it.
It is rather hard to get the mind around it: That, as Dev so neatly explained, the engine runs relatively cool in comparison with front engine cars whereas the exhaust runs a lot hótter, making for a rather complicated temperature management in the engine room.
