Please post if you know stock or modified MRS corner weight values.
I am unsure of exact values, but standard FL car without driver is 42% front, and just under 1000kg IIRC.
Quote from: AdamR28 on August 27, 2020, 20:34I am unsure of exact values, but standard FL car without driver is 42% front, and just under 1000kg IIRC.
About 43/57 and the weight of 1000kg is a bit hopeful for a pfl even as it is for the most basic version of the MR-S.
It really needs scales to have accurate factual data.
What values do you have?
I'll chuck mine (02, poverty spec) on proper scales soon.
Quote from: AdamR28 on August 27, 2020, 23:15What values do you have?
Not corner weighed. Only the whole car on the certified scales accross the road; 900 kilos wet, ready to drive, 10+ l. petrol.
Your car isn't exactly standard though ;D
Only one way the weight has moved from standard with all of the
@Petrus additions!
Quote from: AdamR28 on August 28, 2020, 10:33Your car isn't exactly standard though ;D
Says 1060 kg on the vehicle registration docs.
PFL without AC, no frunk stuff (spare tyre, lid, bucket), PAS pump and lines removed, 6 speed gearbox, slightly smaller than stock tyres (185 rear and 175 front), everything else standard, with about 25kg of fuel on board.
Neat value.
Mine:
