The Workshop => Maintenance, Problems & Troubleshooting => Topic started by: Bad Dog on January 2, 2021, 23:39
Title: Radiator
Post by: Bad Dog on January 2, 2021, 23:39
Going to change my radiator 'cause it's looking threadbare. What coolant do I need and what is the total capacity of the system, might as well refresh it all while I'm there 😁 and is it necessary to use deionised water ?
Title: Re: Radiator
Post by: Bad Dog on January 2, 2021, 23:42
P.S. is there somewhere on this site that has all the basic capacities quantities grades etc ? Have looked but not found if yet ?
Title: Re: Radiator
Post by: Ardent on January 2, 2021, 23:43
Coolant capacity, from grape juice influenced memory, is about 9 litres. (ish)
Title: Re: Radiator
Post by: Ardent on January 2, 2021, 23:44
Quote from: Bad Dog on January  2, 2021, 23:42P.S. is there somewhere on this site that has all the basic capacities quantities grades etc ? Have looked but not found if yet ?
Yes. Somewhere.
Did you get a handbook when you bought yours.
Title: Re: Radiator
Post by: Call the midlife! on January 3, 2021, 09:54
You need red OAT coolant, at least 10 litres for a full system refresh.
Title: Re: Radiator
Post by: Bad Dog on January 3, 2021, 22:44
Is it necessary to use deionized / distilled water ? Or will tap water suffice ?
Title: Re: Radiator
Post by: 1979scotte on January 4, 2021, 05:51
Quote from: Bad Dog on January  3, 2021, 22:44Is it necessary to use deionized / distilled water ? Or will tap water suffice ?
I'm lazy and buy the pre mix.
If you want to use concentrate then buy deionised water also.
I would only use tap water in an emergency.
Title: Re: Radiator
Post by: normanh on January 4, 2021, 17:06
Doesn't it come premixed?
Norman
Title: Re: Radiator
Post by: Gaz mr-s on January 4, 2021, 17:18
It's 50% Red, 50% water.  (I hope.... ::) )
Title: Re: Radiator
Post by: Dev on January 4, 2021, 17:30
You should always used deionized water to dilute Toyota Red coolant from its 100% strength. The mineral salts from the water would be bad.
The premix often referred to as the pink is the newer Super OAT formulation which is longer lasting. It is different but backwards compatible with our car but not for some of the older radiator designs.
From what I read it is the older red coolant is what many Toyota aficionados feel is better because it has been proven for over three decades that it holds up incredibly well even in cars that never had its coolant changed. Even though the pink premix Super OAT last longer it tends to degrade sharply if you go over the change interval.
Both are good but I prefer to sick to red. My car mostly sits now with less millage  so I had my coolant tested since it hasn't been changed in over 10 years and it easily passed.
My other car uses the Super OAT and its near the end of its life after 7 years but I will use the pre mix only because I do not want to deal with any unknowns since it calls for the pink.
Title: Re: Radiator
Post by: 1979scotte on January 4, 2021, 17:30
Quote from: normanh on January  4, 2021, 17:06Doesn't it come premixed?
Norman
You can buy either.
I wouldn't bother buying toyota long life again the rads don't last long enough.
Last load I bought was Euro Car parts own premix cheapo
Title: Re: Radiator
Post by: 1979scotte on January 4, 2021, 17:33
Quote from: Dev on January  4, 2021, 17:30You should always used deionized water to dilute Toyota Red coolant from its 100% strength. The mineral salts from the water would be bad.
I'm sure this is great advice Dev but many uk rads don't last 10 years. I personally think for the UK toyota pink or red isn't good value it's extremely expensive just to have it leak after 5 or 6 years.
If I had a stock car I would probably change rad and coolant every 5 years the rads are cheaper than 5 litres of Toyota pink.
Title: Re: Radiator
Post by: Dev on January 4, 2021, 17:41
Quote from: 1979scotte on January  4, 2021, 17:33
I didn't realize it was that bad. Our radiators are starting to show their age over here but only after 20 years which is approximately the service life for most but most like mine has been going strong.
 What do you think is causing these radiators to fail so quickly.
 I know that rust is a big issue for you guys but even in our  north east states most hold up well with very little reported corrosion.
 I wonder if the salts that are being used during winter corrode these cars.
Title: Re: Radiator
Post by: 1979scotte on January 4, 2021, 18:01
Quote from: Dev on January  4, 2021, 17:41
Uk salt is the worst in the world by far.
We definitely have more failed rads and sub frame than anywhere.
I had a 2006 which need both a new rad and sub frame. It had full service history and 55k miles.
Edit
That was back in 2014 so the car was only 8 years old actually probably only 7.5.
Title: Re: Radiator
Post by: Dev on January 4, 2021, 19:18
Quote from: 1979scotte on January  4, 2021, 18:01
Edit
Sorry to hear that. In my state they changed the mixture to salt and sand for traction. Its now less brutal on cars but in the spring we have sand everywhere until the street cleaner machines are able to clean it.
Title: Re: Radiator
Post by: Ardent on January 4, 2021, 20:54
I have rural sludge to deal with in my playground. Sand sounds nice option. :)
